Question about Zanussi Washing Machines
On any cycle my zwf1621w will not take the softener from the tray could it be blocked and if so is it easy to rectify.
    President:
  • 1,462 Answers
For a start take the tray out and clean thoroughly.
Posted on Jun 22, 2008
THE SOFTENER TRAY IS FILLED WITH WATER AT END OF CYCLE
The fabric softener tray is flushed between cycles to remove residue.
Nov 10, 2017 | Washing Machines
Hi I own a Defy Automaid 600 and has never used fabric softener before. How do I go about
It's very easy- you pour it into the conditioner tray before you start the washer- like the detergent/powder- and (normally) the washer directs water into the softener tray on the (final) rinse.
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash (pre-wash detergent) and see where the water runs in, then advance to the main wash (main wash detergent) and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 05, 2011 | General Washing Machines
Hi I own a LG intellowasher WD8013C and the inside of the dispenser needs a good clean due to the built-up of hardened soap powder. Is there a way to unhook this so that i can be cleaned? I suspect this...
Hi from retired Englishman in France,
Absolutely right! If the tray is blocked with a mix of powder and softener the softener will not easily syphon into the drum and water tends to be left in the tray. Some water is not unusual, though.
Very easy to remove. Most trays are stopped from coming out by a catch/lip on the top at the back in the middle. Often, if the middle tray is the softener, it is there.
Just bend down to eye level with the top of the tray and you should see which bit is sticking up. Gently press it down and pull the tray out!
I give ours a good clean every few months as my wife tends to allow some powder to spill into the softener tray- but don't tell her I told you so, please!
Best of luck,
John C
Jan 24, 2011 | Washing Machines
Washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Aug 23, 2009 | Bosch Washing Machines
Bleach & Softner not dispensing correctly
I finally figured mine out! Remove the dispensing tray then take a small brush, or maybe a q-tip and clean out the small hole right above the softener tray. Mine had mold in it and wouldn't let the water fill the tray, which is what causes the softener to dispense!
Jul 21, 2009 | Whirlpool Washing Machines
Detergent tray full of water
Hi....Lift the softener cover off the tray and you will find the syphon tube or the cover underneath are blocked. Push some wire through the syphon tube to make sure it is clear and give everything a good wash.
Jun 03, 2009 | Zanussi WJD1257W Front Load Washer
SIEMENS XLM 1600 (WXLM166AGB) MACHINE WILL NOT TAKE IN SOFTENER FROM DETERGENT TRAY
If water is being dispensed from both sides of the detergent tray, dismantle washing machine and remove top plate of the detergent tray and clean thoroughly. Water overflows from both sides during the rinse cycle to add softener to the rinse. On our washing machine it was blocked. During the service it was changed but can be washed out to solve problem.
Aug 28, 2008 | Washing Machines
Bosch Classixx 1000: Won't drain
Hope that helps
May 26, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
97 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
