Question about Uniden Cordless Phone
Model EZl 996
Display shows new :30
total :30
I place a call--the phones rings--person picks up and says "hello". I can hear him but he cannot hear me
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
Cordless phone has error message "get closer to base", the phone rings but you can hear person or If I call the phone, it rings but answer machine does not activate????
the get closer to base message displays when you are too far from the phone's docking station. It could be as simple as replacing the battery with a new one from radio shack or such electronic places. But then again I don't know if it was damaged, dropped, or got wet, so this is my most reasonable solution.
Dec 10, 2010 | Panasonic KXTG2344 Cordless Phone
For a GE ProSeries telephone Model 2-9980A S/No 00098864 corded business phone - 1 line with speaker phone. What are the directions to forward the phone to another number? And, also, how to cancel the...
Go to settings on your phone, click on the phone option, it will display different option, select call forwarding or call divert, enter the number you forwarding the call to and press ok, you are done. follow the same procedure, when you get to call forwarding, you can select to cancel as you can no longer add a number.
Take care.
Oct 14, 2010 | Cell Phones
When i make or get call I can hear them but they can't hear me. I get this yellow swiggly object on my screen.
There is some problem with your phone mic only.please use your headset to check it.Connect your headset and answer phone with your headset.If the person don other side hear you then the problem is with the mic only.Please take the mobile to NOKIA CARE centre and they will repair the mic.
The yellow colour swiggly object which comes next to the battery bar is nothing unusual.It shows that your call is been connected with the person on other side.This symbol will not appear when the other person's phone is ringing,When the person picks up the phone this yellow colour symbol will apear.]
Thank You
Thank You
Aug 12, 2010 | Nokia 6300 Cellular Phone
I can't find where to change ring tone or volume
yes go to menu, settings,personal, profiles pick the profile u r using tap on it pick personalise and pick message alert or ring type hope this helps
Nov 12, 2009 | Sony Ericsson Satio Cell Phone
Uniden phone constantly ringing
Hello, it sounds to me like you have a dying battery which may cause the phone to ring constantly.
ryan44z
www.cobaltsys.net
Nov 09, 2009 | Uniden Cordless Phone
Ear phone damaged
Use THe Headset That Nokia Did gives You with your Phone ;)
Sep 22, 2009 | Nokia 6080 Cellular Phone
I can't hear the caller but the caller can hear me!
just need a new earpiece speaker or it simply needs to be adjusted into place. If there is no repair shop around you or you do not want to mess with it, then just buy a $20 bluetooth headset to bypass the whole earpiece.
Mar 10, 2009 | Palm Treo 650 Handheld
# of rings
Hi Sharon,
The rings you hear when dialing your phone number is a machine in the local telephone office that is in place so you have something to listen to while your call is being processed and not your actual phone ringing, also the caller ID requires one to two ring cycles to gather the information it displays on your screen therefore the amount of rings you hear when calling a number rarely matches the actual number of rings at the phone you are calling. There is no programming in the Samsung 100 to change this as it is controlled by your local phone company. Hope this helps explain the situation, Good Luck
Jul 29, 2008 | Samsung DCS 12 Corded Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
