Question about LG Washing Machines
My washer leaks at bottom of door? - LG Washing Machines
  • BobOh619 Feb 18, 2009
    I have the same problem, I might give that a try. After looking at my washer the problem in my opinion is the tub appears to be further back than it was when it was new. The tub is hooked to the rubber seal in the front. It you grab a hold of the tub and pull it forward the door theseal moves forward making a better seal. I am wondering if the vibration of normal operation have moved the inner assembly back. I'll let you all know.
    President:
  • 1,462 Answers
Often happens.
sometimes can be cured by removing door gasket from cabinet and carefully bending the flange outwards with a pair of pliers
Posted on Jun 22, 2008
Leaks from bottom of door
If it has a filter at the bottom of the washer, clean it. Also check the tub seals. Some washers have a seal on the tub or the door. And a bottom door seal. If they are warped or damaged it could leak. Also check your leveling screws. Make sure it's not titled foward.
Dec 24, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Water Leaks out of bottom of door
the first thing i would try is to loosen the hing screws couple of turns,push in on the bottom hinge and tighten screws.
Dec 10, 2013 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washer
No offense, but I think it's time for a new washer. The only thing that comes to mind for leaking would be a broken hose. Is it leaking out of the bottom bottom or like the bottom of the door?
Jul 06, 2013 | Washing Machines
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG front load washer -- water leaks out the bottom of the door -- if I push on the door while its running, the water slows/stops leaking...
First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
Jun 25, 2009 | LG WM-1832C Front Load Washer
Washer has a water leak coming from the bottom!
usually this is the front seal around the door they do crack with age. you will have to pull the front of the washer off to change it any appliance parts co. should be able to get you one
May 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
Leaking from bottom of washer
Do you have the little door at the bottom to collect lint and stuff that goes through the washer? I had a leaking problem once when I simply didn't tighten it enough. Check that.
May 06, 2009 | Kenmore 94702 Front Load Stacked Washer /...
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Water leaking out the bottom of the door
You most likely need to make a small adjustment to the door. While the door is open push the bottom of the door towards the machine and pull the top of the door away from the machine, be careful not to go too far. that should take care of the leak. Before you do that make sure the water is coming out between the glass and the seal. I would remove the lower panel and make sure the seal doesn't have a small hole. You should see the seal leak from the inside. Hope this helps
Jan 13, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
