Not reading CD drive
My computer does not reflect as of just today that it has a CD drive nor does it read CD's when they are inserted.
  • Akash patel
    Akash patel May 11, 2010
    OK, Budy hear are the some reason of your problem thats
    1)Your cd rom's jumper setting may be not completed.
    2)Try to joined another friend's cd rom and see if cd rom will be detect thats problem of your cd rom and change your cd rom.
    Guru:
  • 1,342 Answers
Have you added or removed any software lately?
Read This
Posted on Jun 22, 2008
    Problem Solver:
  • 11 Answers
Some times the problem is with the windows where some action you've done caused the deletion of the driver of your cd, you could try fix that by restoring your system follow these steps:
1-start menu
2-programs
3-accessories
4-system tools
5-system restore
from which you chose to restore you system to the recent restore point, if not working try the one earlier and so on untill its OKay.
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
Pioneer DVR-112D refuses to read CDs?
This unit has alot of issue with CD reading and writing probably its a problem with the lens of this player, so since its still new better take it to the store and have it replace..
Hope that helps........
Aug 10, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Readable DVD's but not CD's
That is a faulty lens. The lens reads DVD and CD on different laser beam frequencies. To read the TOC initial track the lens must focus on the laser beam reflected by the disk. If the lens is opaque, scratched or dirty, sometimes it can focus on DVD but not on CDs or the opposite.
Try using a cleaner disk, if that does not work buy a replacement drive. Today you can get a dual layer DVD RW for less than $30.
Sep 25, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Toshiba satellite a65-s1762 dvd-ram drive problems
Take the laptop *and* your DVDs/CDs to a qualified technician.
It seems like the drive is "intermittently" failing, and needs to be replaced.
Apr 22, 2009 | Toshiba Satellite A65-S1065 Notebook
Combo Cd/Dvd Drive is not reading Cds nor DVDs
1. Remove your burner from your computer then open it by removing the screws under the burner.
2. When the cover has already been removed, get a cotton bud then soak it in alcohol to clean the lens. Because the lens might just be dirty. Then after that put the cover back by screwing it again then install it back to your computer.
Apr 08, 2009 | LG GMA-4082N 8X SLIM DVD RW DRIVE FOR...
My laptop Not reading any CD/DVD
Go to Device Manager by "right-clicking" on "MY COMPUTER", and choose "MANAGE". Once the new window comes up, look for "DEVICE MANAGER" on the left hand side of the screen and click on it.
On the right hand side of the screen you will see a long list of items, look for DVD/CD DRIVES and click on the + sign next to it to expand that list. Now look for your DVD/CD drive and right click on it and choose uninstall. Then restart your computer, when it restarts it will say "FOUND NEW HARDWARE, ATTEMPTING TO INSTALL" wait for it to finish and tell you that it's ready and try to insert a disc. If it does not read it, the Drive might be bad so you might have to replace it...Good Luck!
Dec 02, 2008 | Computers & Internet
DDW-081 CD\DVD Recorder can't read CD
It is possible for your optical drive to read only DVDs and not CD. This is most likely a fault with your drive and may need a repair or replacement.
Aug 24, 2008 | Computers & Internet
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
