The error code dH on your LG refrigerator is indicating a water supply problem. This could be caused by a few different issues:
Clogged or frozen water line: The water line supplying the icemaker and water dispenser may be clogged or frozen. This can prevent water from flowing to the icemaker and dispenser. Check the water line and make sure that it is not clogged or frozen.
Water inlet valve: The water inlet valve that supplies water to the ice maker and dispenser may be faulty or clogged. This can prevent water from flowing to the icemaker and dispenser. You can check the water inlet valve and make sure it is functioning properly or if it is clogged.
Water filter: A clogged water filter can prevent water from flowing to the icemaker and dispenser. If your refrigerator has a water filter, make sure that it is not clogged and has been replaced recently.
Water pressure: If the water pressure is too low, it can prevent water from flowing to the icemaker and dispenser. Make sure that the water pressure in your refrigerator is adequate.
You should first try to check the water line, water inlet valve, water filter, and water pressure. If none of these solutions work, please contact a professional technician or LG customer service to diagnose and fix the problem.
Usual method is a small bore tube from the bottom of the washtub to a low pressure switch so the brain knows when the water level is correct and stops the fill.
It isn't unusual for the tube to become clogged with soap residue and limescale and flooding is the result. Sometimes the switch develops a fault and sometimes a wire falls off.
If washer hums but doesn't fill, water isn't getting to washer check screens where fill hoses connect to washer. Screens may be blocked. If washer fills then hums check to make sure belt is on. Tip machine up to view belt underneath.
You need to check for the Humming noise as this can be the indicator to the problem, if this comes from the motor then the capacitor is faulty. Failure to switch on the INLET and the DRAIN pump can be related to fault in the control panel or this can also be due to faulty electric line voltage on the outlet.. So please check this out. Also check the inlet and drain filters for clogging as a clogged drain pump can also hum.
I'm not familiar with the model number and you have not supplied a manufacturer, however, this is almost
certainly a simple problem with your empty pump filter being clogged. The empty
cycle is timed and if it can't get all the water out in time because the filter
is blocked and slowing the empty down, then it will fail safe and won't step on
to the final spin cycle with excess water in the drum. You need to
locate and clean the filter. Depending on the model, there is probably a round filter cap on the front of the
machine at the bottom (It may be behind a small door or hidden behind a clip on
panel on the bottom) Many models of
this design also have a small hose to the right of the filter cap that you can
pull out, remove a plug from and drain off any water in the filter before you
remove the filter and get your floor wet, so take a look for this before you
remove the filter and get soaked.
sorry but make sure when you have question write model # and make becuase some unit are different.
i would first try to see if water is clogged at the bottom of unit.then i would check the drain hose to make sure it is not clogged. your drain pump may be clogged with something in it.if you hear it humming it is probably good but,it is alsoprobably clogged. let me know is this was helpful with 4 thumbs up
It could be that the machine isn't filling properly with water- which could be a faulty or clogged water inlet valve. I'm not quite familiar with Inglis, but if you still have the manual, check and see if there is a way to adjust the amount of time the water valve stays open at the beginning of the cycle.
Or just add a liter or so of water at the beginning of a cycle and see if that helps- but make sure you add it after you hear the soap dispenser open- the beginning of most wash cycles is a quick rinse cycle, so any water you add will only be in there for a couple minutes before the machine drains and attempts to refill.
