Question about Frost Inglis 17.6 Cu. Ft. -Free Top-Mount Refrigerator - Silver - IT18SKXRD
Cant find the nameplate
Where do i find that? i have looked everywhere inside and outside the ref but i cant find anything that says the wattage.
    President:
  • 1,462 Answers
Usual places are
in fridge on side or behind salad crispers
in freezer at bottom maybe hidden by a basket
Posted on Jun 22, 2008
What is the peak starting wattage and running wattage of a Samsung SD162Q fridge compressor, I am trying to run it ona 500 watt inverter with a surge peak of 1000 watts ?
You might need 3 or 4 times the average power consumption of a compressor. A 500W inverter is not anywhere near enough to start a fridge.
Feb 23, 2015 | Inverter Electronics - Others
Change oven light
You can check the nameplate on it bulb its not ahigh wattage globe but the cover is not easy to get unless yo get an old one
Sep 13, 2014 | Microwave Ovens
For security lighting that is installed under windows, should I choose a low or high wattage bulb?
You shouldc hoose a low wattage bulb. A low wattage bulb under windows will enable you to see any activity going on outside from the inside of your house.
May 09, 2013 | Home Security
My Impact 36LP runs fine under small load (lights/TV/Fridge), however when I turn on my RV A/C unit the generator slows and stops after about 2 minutes. JD
the generator is rated for a certain static load. it may also have an intermitent loading. when the critical load value is reached the engine slows down because the load is too much. add together all the wattages of your loads to get a final load in watts and check against the nameplate wattage of the generator.
Dec 22, 2010 | Electrical Supplies
Microwave oven wattage question
hi, you are correct it is 950 watts as you have read this on the microwave itself, when they sold these they kept the same model number but as they bought newer ones out the wattage increased so they kept the same number so its nothing to worry about it was just yours must have been a newer model then the first ones they made.
the first ones they made started at 700 then they did an 850 then a 950 so you are right its just a case of giving the same model number as the only difference is the wattage everything else is exactly the same, you wouldnt tell the difference if you had them side by side as its only the wattage that changed on this model
Jul 10, 2010 | GE JES735WJ Microwave Oven
My 2000 durango is overheating. I changed the thermostat, the hoses look good, and the fan kicks on. It overheats in just a few minutes of driving and coolant is everywhere, i just cant tell where its...
You need to find where the leak is. You don't mention where the coolant is going. You just say everywhere...so...take a look at the water pump, lower end of the block, trans cooler if outside vehicle and heater core if insdie the vehicle.
May 26, 2010 | 2000 Dodge Durango
How do you i.d the washer type one has?
Look for a silver or white nameplate or label inside the edge of the door opening or on the outside of the back panel.
Nov 04, 2009 | Audio Players & Recorders
What is the amperage rating for the kenmore 30'' electric built-in oven model number 911.41065791 at 240volts?
most ovens just inside the oven door on the top edge have a metal nameplate with model# and the wattage at X# of volts,it could be on the rear but most in frt,take total wattage and devide by input (supply)voltage i.e. 240volts(example 12,000watts/240volts=50 amps)
Jul 11, 2009 | Ovens
Outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Jun 15, 2008 | Weather King 10AJA4201AH Air Conditioner
Adjusting convergence grid
i correct grid will look all white. all colors aligned up.
you should be able to move the lines with the remote. and you cant burn anything out by doing convergence.
Jan 27, 2008 | Samsung HC-P4752W 47" Rear Projection...
Refrigerators Logo
55 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
Charles T Nevin
Charles T Nevin
Mike
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
