Question about Bosch Washing Machines
Rugs won't dry
I have a new Bosch WFMC8400C. I just washed a couple of small area rugs. Now, I can't get the excess water out of them! Is there a spin only cycle that will help get all the excess water out?
  • 2,071 Answers
Your motor that drive has a problem if have a intermittent problem,you checked motor belt it is weak already
Posted on Jun 23, 2008
    Sergeant:
    Champion:
  • 248 Answers
Just air dry your rugs instead.
Posted on Jun 22, 2008
Do area rugs fade?
There are lots of factors which are responsible of fading of your area rugs mostly rugs fade on the areas in which they are continuously in exposure to sunlight, good quality rugs do not fade under normal conditions the rug company also provides some years of guarantee on color of rugs.
Oct 17, 2014 | Concord Formal Leopard Area Rugs Formal...
How do we remove the horrible smell in our Bosch dishwasher?
First check out your model to see if it has a built in garbage disposal, if so, make sure it is not mucked up.
Run hot water down your sink drain while running the sinks garbage disposal. Pour baking soda down your sink garbage disposal followed by white vinegar. Let it sit and foam. Run hot water down sink disposer while running. When finished:
Run empty dishwasher with no soap, let dishwasher fill with hot water to wash and then pour 1 cup of white vinegar into the bottom and resume wash. Make sure you take it through the dry cycle. When finished, open dishwasher and let it air for a couple of hours, longer if you live in humid area. Hope these steps do the trick.
Aug 03, 2014 | Bosch Dishwashers
Installed new ink and now won't print anything, not even a test page. says error. deskjet 4400 series
Each ink cartridge has a metal, thin Copper 'plate'.
In this 'plate' there is a series of VERY small holes. The holes are so small it's hard to discern their existence, with just the ***** eye.
The area on the printer's body, that the copper plate matches up to, also has matching holes.
After a given time the ink dries up in these tiny holes.
The dried ink needs to be removed.
Printer UNPLUGGED from power, printer case open.
I would suggest wearing dish washing gloves, and remove all ink cartridges.
Small bowl half full of distilled water as hot as you can stand it, dip a clean, lint-free cloth in it. (Distilled, because non-distilled water can leave hard water spots)
Squeeze all excess water out until the cloth is damp. (D-A-M-P) Wipe the area on the body of the printer.
I would suggest wiping in one direction only. Wipe, then go to a fresh, clean part of the cloth, wipe again.
Keep wiping until the cloth picks up No ink.
You may want to follow suit on the ink cartridge/s now, as they may have picked up dried ink.
Suggest use a can of compressed air for computers, and make SURE all areas are D-R-Y.
Allow the printer to set open to dry afterwards. May only take 30 minutes, or less.
Ensuring all surfaces are dry from the water, reinstall the ink cartridges.
Close the printer's case. Plug back into power, WAIT 1 minute, then turn on.
Regards,
joecoolvette
Dec 10, 2011 | HP Office Equipment & Supplies
I get an E 13 message. I've detached the drain hose but it was clear. Can't open door or try running any other program. I have a small rug in the washer and I fear it's the cause of the trouble. Please...
To remove the drain pump access cover, insert a pointed object (or tool) into the hole, push in to release the latch and rotate the cover clockwise.
If you have a wet dry shop vac attach it to the end of the drain hose to remove any water.
Then remove the drain pump plug and clear out the area keep the shop vac handy as water will still come out of the plug.
Once this is clear you machine will start.
There is also a white plastic zip tie like cord you can pull in order to open the door
Jan 09, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
BOSCH WFMC3200 Washer - Receiving E04 error and manual indicates clearing drain hose and pipe. How do I remove the cover on lower front of machine?
there is small hole in the cover you need to push a small screwdriver or ice pick works in the hole and then turn clockwise till it comes off.
But there will be some water come out so if you have a wet dry shop vac then use it on the end of the drain hose to remove most of the water then keep it handy when you take the plug out there will still be some water come out and you should be able to clena out the trap area
Nov 30, 2010 | Bosch WFMC 3200 Front Load Washer
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Rugs won't dry
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate.
Pl rate me 'very helpful' for the free help, thanks!
Jun 22, 2008 | Bosch Classixx WFL 2066 Front Load Washer
I have a new washer. Less than 2 months old. I always use the regular cycle but today I needed to wash a very small rug. I used the quick wash and iti took forever. Then at the end( after the cyle) the rug...
I just need help. I do not want to pay anything to have this question answered. I paid $1,200 for these two new appliances less than 45 days ago! I thought this site was connected with GE. Apparently not.
May 26, 2008 | GE Washing Machines
New Bosch water not draining
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Oct 16, 2006 | Candy DQW150 Front Load Washer / Dryer
Washing Machines Logo
78 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
