Question about Vivitar ViviCam 8400 Digital Camera
Pictures from camera to card
How do you move pictures from the camera to the card. I cannot see the camera pics when the card is installed.
  • sar46ah Sep 03, 2008
    YES, MY PICTURES ARE ON THE COMPUTER, I WOULD LIKE TO GET THEM BACK ONTO MY CARD SO I CAN TAKE THEM TO A KIOSK FOR PRINTING.
  • 2,794 Answers
Usually when your camera is installed to your computer, it appears as a disk drive device. If you go into my computer you will see a different icon for you camera. It probably says removable device underneath it. If you click on the icon, click the correct folder that your pictures are stored in you should be able to see them.
Heres a copy of the owners manual if you need one:
http://www.vivitar.com/ecms.aspx/fe7fbbaf-80fe-476d-931f-eaab8d2e2e35/SupportFiles/CameraManual.pdf
Posted on Jun 22, 2008
Does anyone know how to transfer pictures from the camera to a memory card? I thought my card was in there when I took the picture, but it wasn't.
most all cameras cannot move pics from internal memory to memory card. You first have to save them to your hard drive with a usb connection. Then you can move the pics to the memory card if you have a card reader. Or... replug the camera into usb after installing the memory card. Then you can move the pics to the memory card. Note: if trying the later you have to name the pics following the same naming convention as the pics already on your memory card. otherwise, they will not show up or will replace those that already exist on the card.
Aug 09, 2010 | VistaQuest VQ-5115 Digital Camera
Is it possible to transfer pictures from the camera memory onto a card? I have taken pics and then put the card into the camera and want to put the pics on that card
yeah you just pick the picture you want to send to memory card. you click on options go on to move and click on memory card or external memory.
goodluck:)
please rate this solution...
Jun 08, 2010 | Cameras
Didnt put in memory card, but want the pics in the camera
the picture will either be on the internal camera memory if it has it or a card when installed. Both will come off the same way. Plug into the usb and the camera will be recognized by the pc. You can either use my computer or the management software that came with the camera to move or copy it off. It will show up as an extra drive or two.
Mar 23, 2010 | SVP CDC-8680 Digital Camera
What does read error mean and how to correct it?And get the pictures it seems to have misplaced.
Rhonda, You should remove the memory card from the camera and insert it into the card reader of the PC and move all pics to the PC. Then insert the card back into the camera and format it with the camera. Then whatever pics you take will be saved to the camera and be read by it too. Now for some reason the camera can not read the card. And if you want to use it then the camera should be able to read it. To do that you must first move the pics to some other place and once the pics are safe then the card can be forgotten.
Nov 29, 2009 | Fuji FinePix S5000 Digital Camera
Olympus FE-370 I have 10 pictures on the camera (tok pics without realising there was no card inside!), but I cant seem to save them to the memory card - I have lost the lead for the camera. Is there...
See page 34 of the manual (available for free download from Olympus below).
http://www.olympusamerica.com/files/FE-370_X-880_C-575_Instruction_Manual_EN.pdf
Or in short, select the "Setup" (tools) menu, and then select "Backup". You'll need to have the memory card installed for the transfer.
Jul 04, 2009 | Olympus FE-170 Digital Camera
Chip says full after few pics
The chip may not be inserted correctly. You can tell by seeing or not seeing SD symbol in the view screen. Try removing the SD card. Go through the memory and see if the pictures were saved to the camera or to the card. If the pictures were saved to the camera, turn off the camera and re-insert the card. See if the cards responds by showing more pictures available for taking and move the pictures to the card. If the pictures were saved to the card, then the card may need to replaced.
Dec 31, 2008 | HP Photosmart R717 Digital Camera
Not able to 'delete' a picture from my Lumix TZ3
Sounds like a MobileMate quirk Tanya. Use your USB cable connection to your PC/Camera interface and delete pics that way too see if this funny goes away.
If it does, and I believe it will, then it is a SanDisk issue not revising the File Allocation Table(FAT) after deleting the Pic File on the mem card.
You could also find out if this is just an SDHC SD card reader issue by using an older less dense standard 1 or 2Meg non-SDHC mem card in the reader and see if issue goes away.
The fallback of course to view and delete the pics on the camera before download, or download pics then note which pic file numbers you want deleted after viewing on PC, then put SD card back in camera and delete them there.
Another option for trial, is to cut and paste the whole DCIM folder, or sub pic folder to your PC from off the SD card using the card reader. The camera automatically generates subfolders under the DCIM folder if you completely remove(deleting by a cut or move), when you take your first picture on a camera with a DCIM but not sub pic folder. Try this first and I think you will find all pics will be deleted from camera that are in a subfolder under DCIM. If not, then cut or move the whole DCIM folder and create a new DCIM(empty) folder on the SD card using the PC and card reader. Of course using this method you cannot selective delete individual pics from the mem card. You would be deleting them all after the Folder cut or move from the SD card.
Dec 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Moving pics from my camera to my memory card
press the green arrow to see your pictures. press menu, go to copy and select internal to card. that will move your pictures for you.
Apr 04, 2008 | Casio Exilim EX-Z57 Digital Camera
Transfering pictures onto the CFC
i have the same camera.i have the memory card in the camera,and it says the pics have been transfered to the card.when i try to download the pics to my pc it says the card is empty, no pics
Oct 19, 2007 | Pretec DC-600 Digital Camera
Vivitar ViviCam 8400 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
