Question about Sanyo SC-H2000 Bagless Upright Vacuum
Hose fell off
My hose came off the vacuum and I can't seem to get it back on because the hose is bigger than the hole. Does the hose get glued on? Am I missing something?
    Master:
  • 638 Answers
The hose attaches to this plastic piece leads to the part where the dirt goes. see the pitchure
Turn the knob to the water only, put the piston on the bottom of the knob then turn it slightly so it doesn't fall off, Start to put the cover on, when it is straight, turn the knob to the water only selection and push the top all the way down. The piston should have gone into the hole and the knob should turn easily.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 22, 2008
    Genius:
  • 1,142 Answers
Hi
Normally the hose comes with a plastic round lock on the face of the vacuum machine
  • Maanita Chadha
    Maanita Chadha Jun 22, 2008
    Refer to this link
    http://www.raven1.net/sabot9.jpg
  • Maanita Chadha
    It comes with a ring lock too
  • Sanyo Master
  • 19,396 Answers
The hose should have a small plastic lock Check if the part is broken.
How to fit hose?
Some vacuum cleaner hoses are glued onto the metal fittings. If you are replacing one, the old hose has to be cut to remove.
Apr 18, 2016 | Vacuums
Dyson DC14 hose won't extend and floor unit lost suction
Sounds like the exhaust side is clogged. Remember a vacuum pulls air into the cavity, but for it to work properly it also has to be able to exhaust the same amount of air it takes in. If the exhaust is blocked it will continue to suck air inside and collapse on itself, which is why your hoses are getting shorter and harder to move. Check the exhaust system for any blockages, perhaps the hole you taped was the exhaust.
Mar 15, 2015 | Dyson Vacuums
BAD SUCTION WITH ATTACHMENTS
You may have a small leak in the hose somewhere, that may be getting bigger, thus losing more suction.
Jul 21, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Vacuum has lost suction and is making a hissing noise
I had the same problem with my Kompressor.Initially I had cleaned all three removable filters.There is two in the canister that can be washed with dish soap. The HEPA filter is located in a compartment on the lower front side of the vacuum.This HEPA filter should not be washed.I found that tapping it inside a trash can dislodged alot of dust from it. After cleaning all the filters and canister I was having the same hissing noise coming from a small hole near the bottom of the vacuum. Next I removed a hose fitting on the lower back of the vacuum and that is where I found a very large amount of debris clogging up the hose. I used a metal coat
Nov 11, 2011 | LG Kompressor Upright Vertical Cyclone...
I just got the majestic and it doesn't seem to have a lot of suction power- I ran water thru the hose and it drained out fine I also put the hose on top and blew it out. Could it still be the hose?-or...
Did you change the filter cone? Clogged pores can and do inhibit airflow. Bent fan blades can be another problem. Holes, slits, and cracks, no matter how small, in the hose can result in reduced suction.
And you should NEVER run water through a hose that contains electrical wiring, which I suspect yours does.
Oct 15, 2010 | Filter Queen Majestic Canister Vacuum
Gear shift fell out
This is an easy fix you do not have to fully remove transmission it does help to lower it down by removing screws. Then try to get the right angle and realign the splines I have fixed mine twice, the second time I put thread locker on it and have not had any problem. Steve
Apr 30, 2010 | Kirby Ultimate G Bagged Upright Vacuum
The hose on my spot bot has torn
yes you can replace the hose for $25
If your unit is less than a year old it will be under warranty and replaced at no charge to you
Dec 15, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Vacuum hose problem
I took hose end off and crazy glued hose back in place.
Dec 14, 2008 | Bosch Canister Compact Plus Vacuum -...
Panasonic Stow'n'Go, model MC-V5481
If you turn the vacuum over, you will see a hose by the brushroll. I think your problem is that it's stopped up right there. Take off the brushroll and make sure that the hose isn't stopped up. The port at the back that makes a hissing sound is to indicate that it's stopped up somewhere. Also, when you replace your attachment hose back onto the machine, does the motor change sound?? That's also another indication that your machine is stopped up. Don't lose hope for the Panasonic, they're great machines. If you still need help, you may call us at 1-866-509-1952. Thanks.
Jul 10, 2007 | Panasonic MC-V7600 Bagless Upright...
Replacing the hose
usually these hoses are glued into the collar, and the only real way to re-use them is to carve the hose/glue out of the collar by hand with a chisel. some will screw out with enough force, but dont break the collars trying. If there is glue it is probably a long shot but you could try some acetone (dont get it on your skin - it is very nasty and absorbs through) - try a little on the plastic first and wait overnight to check that the plastic itself will not be affected, then see if the glue will dissolve out of the join - probably not with the type of glue probably used. Another possibility is that the whole hose and collar are moulded as one piece - if so take it to a workshop with a lathe and get them to try and lathe holes in the collar part for a hose. Sears have proven to be next to useless when it comes to spares, so i would suggest try and find a vacuum repair shop locally and just see if they have a hose that fits hanging about. Hope this helps - please post again if not with a photo - might make it clearer?
Mar 24, 2007 | Kenmore 22313 Bagged Canister Vacuum
Sanyo SC-H2000 Bagless Upright Vacuum Logo
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Thatvacguy.com
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
