Question about Philips Magnavox DVD/VCR Dual Player
T.v. ejecting vcr tape and turning self off after being turned on
My problem is that the vcr deck is stuck in a weird position and requires a tape to be in the player or the t.v. will shut itslef off everytime it is turned on. When a tape is left in it ejects the tape when the t.v. is turned on and shuts itself off. We push the tape in and turn it on again and repeat several times until it finally stays on.
  • Anonymous Mar 28, 2014
    keeps ejecting tapes in play function
  • 10,594 Answers
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Posted on Jun 22, 2008
My tape is stuck inside and i want to eject
Locate any screws that hold the top in place. carefully slide the top off. find the loading motor. it should have a worm gear on it. turn the gear and after a while the tape should come out. is this only in one vcr in the duel deck? please reply if you can fix it. if that did not work, just let me know. good luck!
Jul 09, 2010 | Rio Go Video DDV9050 Dual Deck VCR
Tape deck is stuck
push the eject button at the same time get a nail file and insert it in the tape slot
on the right hand side of the deck
it may take three hands one to push eject one to push the eject mechanism inside the radio behind the tape
and one to help remove the tape
if that doesnt work....dont try forcing anything as the stereo WILL break..... take the stereo out of the car, so it is not connected to the electrics, then either, gently take it apart with a screwdriver
I would suspect the belts, look for any small motors and missing belts. You may be able to manualy turn a wheel or gear till it ejects.
if your not comfortable doing this urself with the above said porcedures... its better to take it to the dealer...
regards iversh
A very helpful rating is appreciated for answering Your Query
Aug 30, 2009 | Panasonic RX-ED707 Boombox
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
VCR tape loads and runs about 5-10 sec; then ejects
you need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
Jan 02, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Sep 30, 2008 | Audio Players & Recorders
Video Go Double deck VCR (Montage), Model #6060/6600/6050
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Feb 18, 2008 | Televison & Video
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit." unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it." unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Feb 16, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Philips Magnavox DVD/VCR Dual Player Logo
537 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
