Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Standby light blinking
My sony trinitron will NOT turn ON, and blinking standby light is constantly blinking... what is the common problem with this?
  • 4 more comments
  • Anonymous Jun 28, 2008
    Same problem, light blinks constantly, but no way to get the picture on via manual or remote. Even my teenagers can't figure out a way to get it on.
  • Anonymous Jul 02, 2008
    standby button on blinking no picture
  • ljmvenoms Jul 05, 2008
    Blinking stand by light and picture will not turn on.
  • aws64 Oct 24, 2008
    Same problem. So ...?
  • Anonymous Mar 16, 2014
    Continuous blinking light in standby mode.
  • Anonymous Mar 18, 2014
    Sony Trinitron standby light is blinking 4 times and will not come on
Blinking six or seven times can i fix it
Posted on Feb 16, 2012
    Scholar:
  • 170 Answers
Starkrayving, this dont even have a light bulb in it. I can't believe some people that think they are techs on here. but i guess give everyone a try. lol how about a hands on tech that has fixed several sony's answer your questions.... follow this link. and follow the steps. one thing that may not be listed is adjusting the screen control on the back of the flyback a lil bit. if you think its on but no picture and the light is blinking. this is a sure sign of the tube getting weak or the flyback. you could get some time out of it if adjusted. everyone else follow the link.
http://www.fixya.com/support/t710012-sony_blinks_6_times_wont_turn
Posted on Feb 27, 2009
I think we had this problem and it meant that the Light bulb inside needed to be changed. You order it from Sony. It costs upward of $200 but fixed the problem for us.
Posted on Nov 25, 2008
Power supply
Posted on Jun 26, 2008
3 Suggested Answers
  • 8909 Answers
SOURCE: my sony trinitron will NOT
If you let us know how many times the light blinks, that will let us know whereabouts the fault area lies. Her is the list. I hope it is helpfull.
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Posted on Jan 19, 2011
  • 10 Answers
It might needs to be charged.
If it does'nt go to the place where you brought it and see whats up with it! =)
Posted on Apr 17, 2011
My sony trinitron television will not turn on. it will click and the stand by light blinks, but there is no picture. can I fix this?
It sounds that there is a direct short circuit in anywhere in circuit board. Most probably, it might be to vertical sweep output section, in Sony TVs. Here you noted that the standby light blinks. Blinking of standby light to Sony TVs are fault indications. Count it, and check this.
Dec 31, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My sony trinitron screen goes black and the standby light blinks
How many times the standby light blinks at a time? Number of blinking of standby light with Sony Trinitron CTVs are fault indications. To know more about these blinks, and fault location, get in this site named Electro-help, and pull up older posts there. Try this link, and select the site.
Jul 11, 2012 | Sony Televison & Video
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron stopped working-standby light blinks
How many blinks are you getting?. Blinking codes tells a service tech what section of the unit is manfunctioning.
The full service manual for KV-24fs120 can be found HERE!
Nov 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony trinitron
Need a little information here...
1. The TV remains on, yet there is no picture and no sound? Or does the TV turn off altogether?
2. Are the blinks constant and continuous? Meaning, does it blink two times, pause, blink two times and go on and on like that?
3. Can you turn the TV on? Or can you not get it to turn on?
Answer those questions and I can give you some more information or send you to the place where you can get it.
Nov 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
2,689 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
