Question about Roper RT21AKXKQ Top Freezer Refrigerator
Ice maker not working
my ice maker is not working, water in tray is frozen but not dropping into bin. Any Help ? my ice maker has ice but it is not dropping the ice
  • 706 Answers
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Posted on Aug 06, 2008
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
The ice make stopped working. There is ice in the water feed tube. The ice maker is full of ice, but it is not dispensing. Ice in the storage bin was frozen together into blocks.
The icemaker in it's operation hits a microswitch to turn on a warmer in the aluminum tray that aids in extracting the ice by the rotating vanes. It may be that that part of your icemaker has failed.
Try this for a solution first. Remove all of the ice from the bin. Using a hair dryer, melt the ice in the tray and the fill tube. Be sure to warm all of the switches behind the plastic front cap in case those switches are frozen. Let the ice maker fill again and see if you have made ice. Often splashed water will freeze the rotating vanes and will not let the ice maker rotate through it's complete cycle.
Mar 08, 2011 | KitchenAid Refrigerators
Bosch Evolution B20CS50SNS about two years old. No ice is dispensed. Looked inside and tray is frozen over solid. Also looks like water has overflowed and frozen down in bin. Could not figure out how to...
I've had lots of problems with my Bosch refrigerator ice maker. The ice tray has a tab on the back corner that twists the tray when it cycle to empty the ice. That tab broke off and when I looked into replacing the ice tray the authorized Bosch dealer said the tray is only sold with the complete ice maker unit. Sells for about $160. I have a hard time spending $160 for another complete ice maker when I only need a $10 replacement ice tray. This ice maker is sub-par for an appliance name brand like Bosch.
Dec 08, 2009 | Bosch Refrigerators
Ge ice maker stoped working
Check out the tray heating element that is designed to melt the ice slightly so it can be scooped out into the waiting tray.
If there is no water or ice in the tray, then check out the solenoid that allows water into the system.
Apr 19, 2017 | GE LightTouch GSC23LSRSS Side by Side...
Ice maker problem
Clear the Ice tray by pressing the button under the ice maker. The problem is that the ice is in the first couple of slots is not dumping and the tray tries to fill again and over flows. I pressed the button and cleared the tray of ice (This will tilt the tray and twist it to empty it) that was re-frozen several times without dumping. My ice maker works perfectly after I did the above. I think the problem arises if the door did not close completely. I stopped hanging the dish cloth on the door and on my LG Dish wisher. I hope this helps
Oct 03, 2008 | LG LRSC26940ST 36" Side-by-Side...
Ice bucket/bin frozen in place
mine was overfilling because the ice was getting stuck on the way out. So some stayed in the tray and when the water would refil, it would overfil and go over the stuk cubes. leaving it to overflow to the bottom and freeze like yours.
Sep 09, 2008 | U-Line Icemaker
GEARS UNDER FRONT PANEL OF ICEMAKER ARE WORN OR BROKE,YOU NEED NEW ONE,THANKS-MIKE
May 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kithcenaid Superba KSRS25QDWH01
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
May 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Roper RT21AKXKQ Top Freezer Refrigerator Logo
595 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
