Question about T-Mobile Wing™ Smartphone
T-mo wing won't allow me to answer incoming calls.
Lately my Wing has begun to freeze whenever I get an incoming call therefore not allowing me to answer it. At first I thought there were perhaps too many programs hogging the space on my phone so I deleted them. That didn't work so I deleted other stuff that could've been taking up space and that didn't work either. As a last resort I reset the entire device in hopes that this would right the problem. It didn't. I'm completely at a loss now. Whenever someone calls the screen immediately freezes, I can't see who's calling and the phone just rings for about 5 minutes. When it's done it goes back to normal without even showing a missed call. Does anyone know how to fix this??
  • vannys_babii Jun 23, 2008
    thanks! I did that and it worked but I think I'm going to consider getting a different phone. I'd hate to go through that process every few months just so that this thing will do what a simple phone does.
  • Anonymous Jan 25, 2009
    my husband and I both have the same phone the T-mobile wing. We both have problems answering incoming calls. We are also both having problmes getting the dial pad to come up. My husband is ready to commit suicide. T-mobile said they would exchange us the same exact phone. I said no thanks we already have 2 and they both have the same problems. so 200.00$ to cancel our service.... such ********.
I had the same problem. Just make sure all your files are saved to your memory card and go to start, settings,system, then select clear storage. this will reset all settings to manufacturer default. It worked for me hopefully it works for you.
Posted on Jun 22, 2008
  • kamehameha19 Jun 22, 2008
    Oh, one more thing I forgot to add, make sure your contact list is saved to your SIM and not your phone, otherwise when you clear storage, you'll lost your contacts
04 gold wing gl1800. There's an Allen bolt under engine next oil drain plug what is the Allen bolt?
Hi, Bill the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda GL1800 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Goldwing GL1800 Owner Manual
Honda GL 1800 Gold Wing 2004
Honda Gold Wing
Jul 31, 2017 | 2004 Honda GL 1800 Gold Wing
Will a 1984 honda gold wing 1200 engine work in a 1985 honda gold wing? I see the pulse genarator was moved from the rear of the engine to the front
Hi, Darren the answer to this question is way above my pay grade and for this situation although my gut says yes, I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Honda GL1200D Shop Manual
Honda GL1200 Aspencade Owner Manual
Honda GL 1200 DX Gold Wing 1985
Honda Gold Wing
Apr 29, 2017 | 1985 Honda GL 1200 Interstate Gold Wing
How do planes stay in sky?
You may notice that wings are usually curved at the top and fairly flat on the bottom. This causes the air over the top of the wing to move faster and therefore have a lower pressure than the air under the wing. The lower pressure mixed with the high pressure under the wing cause "lift". You can demonstrate this by holding a sheet of paper at one edge and blowing over the top of it. The paper will rise as you blow due to the low pressure you're creating by the faster air flow. It's called Bernoulli's principle.
Jan 04, 2017 | Aircrafts
All problems 1981 gl1100
Hi, Anonymous the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Honda GoldWing GL1100 Service Manual
Honda Gold Wing GL1100 Owner Manual
Honda GL 1100 Gold Wing 1981
Apr 09, 2012 | 1981 Honda GL 1100 Gold Wing
Battery
they make a charger called a battery tender which keeps your battery topped at all times with a trickle charge. get one and your batteries won;t die.
Jun 07, 2009 | 1982 Honda GL 1100 Aspencade Gold Wing
Phone freezing
I have has similar problems with smartphones I have had. If you don't already have a memory card for that phone, get one! Memory cards are a necessity with smartphones, at least 2Gigabytes. If that's not the case, then contact your phone company because then it might be a hardware issue in which they would swap out your phone for a new one.
Mar 18, 2009 | T-Mobile Wing™ Smartphone
Unwanted hang-ups
There is a program called Slide to Unlock you can install. It gives you the iPhone like slide action to unlock your phone. It also allows you to set your buttons to no action without first sliding. After installing it, go to the settings and be sure that 'Slide to Answer' is ON, and 'S2A Answer Key' and 'S2A End Key' are both turned OFF.
You can find the software here:
S2U2 Software
Hope this helps!
Aug 28, 2008 | T-Mobile Wing™ Smartphone
Windows media player
Program that came with the wing called active sync, you can also get it from www.microsoft.com, will allow you to sync your phone and transfer media.
Dec 23, 2007 | T-Mobile Wing™ Smartphone
Bluetooth
It is still be under warranty. call t-mo and ask for tech support
Nov 09, 2007 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
54 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
