Vivitar ViviCam 8025 Digital Camera Logo
Posted on Nov 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whenever i want to turn the flash on, i press the flash icon and it says "macro mode" on the screen.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vivitar Master 102,366 Answers
  • Posted on Nov 23, 2010
Vivitar Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10433321
Points
622693
You can't use the flash in macro mode. Macro mode is for taking pictures of objects close to the camera.
To switch out of macro mode, slide the switch on the left of the camera, just above the USB port, away from the flower icon toward the mountain icon.
1helpful
2answers
When I try to turn my flash on it says macro mode, What is this and how do I fix it?
Macro mode is for taking pictures of subjects very close to the camera. In this mode the flash is disabled.
Without knowing the model of your Digital Concepts camera I can't tell you how to take it out of macro mode. If there's a button on the back marked with a flower icon, press it. Otherwise look in the menu.
1helpful
Everytime i turn on my vivicam 7024 and press the flash it says "marco mode no flash". how can i fix it?
The macro mode is for taking pictures of subjects very close to the camera. In this mode the flash does not operate.
There's a slide switch on the end of camera. Slide it away from the flower and toward the mountain to take the camera out of macro mode.
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
I can not change settings, for example, no flash to flash. When I go to take picture "Digital Macro" appears momentarrilly on display.
You're in the macro mode. Macro mode is for close-up shooting, and the flash is disabled in this mode.
Set the camera to the shooting mode (set the mode switch to the camera position). Press the FUNC/SET button. Use left/right to select a different mode and press FUNC/SET.
7helpful
How do you turn the flash on and off? Every time I hit the flash button it says "micro mode" on the screen.
Turn off the macro mode. There's a switch on the left side of the camera, near the USB port. Slide it away from the flower icon to turn off macro mode.
All photos I take have suddenly become blurred on my vivitar Vivicam 8225
The reasons why Photos get blurry might not always be an issue with the lens. Here are a few things you should consider -
1) Check if the Battery of the Camera is fully charged. This can hugely effect the outcome of your pictures.
2) Make sure the Memory Card is not full.
3) Check for the Macro or Normal mode. To do this, simply check the top of the LCD Screen. If you find a "Flower" Icon, then the camera is set into Macro mode. To change this, press the OK/Menu button. Find the Macro menu and press up/down to make Macro Off and Normal (Mountain Icon) to On. The camera is now changed into Normal Mode and a Mountain/Pyramid icon should be there at the top of your screen.
4) Try increasing the resolution. Again press the OK/Menu button and press Right/Left until you find a "Lines" icon. Press the Down/Up arrow to choose the resolution. 8M is the highest. Press OK to confirm.
Note - Higher the resolution, better the picture quality but lesser the number of pictures you can save.
5) Check if there is a Crossed Thunder Bolt icon on the LCD screen. If you find one, the flash has been turned off. To turn it on, press the Up/Thunder Bolt. A Crossed Arrow with an A should appear. This indicates the Camera has been set to auto Flash.
Hope the images get better with these tips. You can always call Sakar International at 877-397-8200
1helpful
The CD that came with the camera will not load onto my computer. I need an instruction manual. I did figure out how to take, delete, ect. but for some reason the flash will not turn on and I get a message...
The flash will not fire in macro mode because macro mode allows you to get close to your subject. Get out of macro mode by pressing a button with a picture of a flower on it or by it.
PowershotSD750 Focus More
Press the left mode-wheel (the side with the flower and mountain icon) until you see the flower (macro) icon in your screen. You're now set to focus on close-in objects, such as type. When you want to switch back, press the left side of the mode wheel once more until you see the mountain icon. You're now set to focus on more distant objects.
2answers
Use of macro digital feature
hi,let me just inform u that the macro mode is only for outdoors.So on the side of the camera u will find a sliding switch.Just slide it to the opposite direction to turn off the macro mode.Since u wanted to take pictures of jewelry pieces,turn on the flash if u have one and then take a closeup shot with good lighting conditions.If its too bright then use only the flash,if u r not satisfied with the quality then use only lights and then take a pic.Still face any prob plz get back to me.
Macro Mode
The MACRO MODE is easily accessed via the arrow pad on the back of the camera. Press the left arrow key, which has a flower icon, to start the MACRO MODE. Press the down arrow key to select the flower icon in the menu. Then press the OK/MENU button; camera is now set for close-up photography. Remember to turn off the MACRO MODE when you begin shooting subjects beyond the focus range of the MACRO MODE.
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
