Question about Samsung HLP4663W 46" Rear Projection HDTV
About my DLP TV that you have helped with
I have the DLP TV that won't turn on. Do you have an idea of what the supply voltage to the color wheel should be? I am getting around 2.5 volts from the dmd board. Does that sound about right? When I hold the door switch and try to turn the tv on I can tell the color wheel does not spin.Oh by the way the LEDs on the DMD board are lit up and there is voltage to the ballast. Do think this would confirm the color wheel is bad?
Thanks,
Brandon
  • mpdejean16 Jun 28, 2008
    My dlp turns off after about 20 sec. I changed the lamp and color wheel. Can you help me?
    Scholar:
  • 137 Answers
Hello Brandon B,
I would go ahead and change the color wheel. I have changed 3 color wheel this week for the same problem.
Best regards
circuitcity
Posted on Jun 22, 2008
What part fails to make distorted or wrong colors and over all dimmer picture on a DLP TV?
You are correct that oit is the color wheel. I wcannot give you a part number at this time because you have not supplied the model number of the set. I hope this helps.
Mar 08, 2016 | Samsung Televison & Video
Tv will not turn on the power light comes on then shuts off again
Hello, have you checked the lamp to see if it's broken? Next thing is was it making a whining noise before it went out? If so the color wheel could be bad. the third thing would be the ballast board, it supplies the voltage to the lamp, Let me know....tks.....Terry
Mar 06, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
Replaced lamp on samsung dlp - will not turn on - color wheel is intact but will not move - it sounds like TV is trying to start up but after three tries all three LEDs turn on - is this possibly a bad...
No,the tv colors wheel it is also dead or lose connections somewhere,because there no movement at all and all the LEDS indication lights are flashing and not giving power voltage to the tv colors wheel part at all.
Jun 22, 2011 | Samsung DLP HL-P5663W 56" TV
I HAVE A PT-50IN LCD14 THATS HAVE YELLOWS SPOTS COULD IT BE THE COLOR WHEEL
? DLP or PLASMA ;dlp have a color but not plasma/
in plasma its could be a floating ground or a bad capacitor
in the video board or filtering capacitor in pwr supply..
hope that give an idea about its problem..
regards Allan (asleletroniq1.
Oct 01, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
About the DLP TV you helped with.
Brandon. Locate CN110 on the DMD its a wire plug. Pin 2 is gorund pin 4 is voltage for the color wheel. When the color wheel is off pin 4 should have 5V on it when power is pressed it should have 7v for the color wheel to start. If the voltages on pin 4 is 5V your DM is ok and Color wheel would be indicated as faulty, But if pin 4 is anything less than 5V its the DM which is faulty.
Jun 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
I need help with my DLP TV
If you have verified the votages are there at the color wheel and its not spinning the color wheel is most likely defective. the sound you hear when spinning by hand is most likely the bearing but that shouldnt stop it from spinning. but as i said if the supply voltage is present but it still wont spin. the color wheel must be defective.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4663W 46" Rear Projection HDTV Logo
79 people viewed this question
Henry  Thomas
Henry Thomas
