05' Mits projection TV model # WD-62725 - won't turn on. little green light by power button is just flashing. tried unplugging for 40 min. no fix?? any suggestions?
Hi, If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
just happened to us, we unplugged in from the surge protector and plugged it in the regular wall outlet and were able to get the tv to come on, don't know why, but it worked
The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacement capacitors and the step by step instructions on CD
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
I purchased my WD 62725 in January of 2005 and have had way too many problems with something costing this much. My green reset button is now blinking and I have read and tried all of the suggested solutions. All of them have failed. I sure think Mitsubishi should be held more responsible than they seem to be. Some one suggested a class action lawsuit. I would sure join one. Jack P
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Try holding the menu button on the tv while turning on the tv.The other problem might be the connection to the lamp in the tv.They have a nasty habbit of coming loose ore falling out if the lamp is inserted to hard.
