Question about Hotpoint Dryers
Belt could you please tell me how to fit a new belt to my dryer tl32w thanks julie
  • 525 Answers
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0079.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 22, 2008
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
Dec 26, 2014 | Tricity Bendix Dryers
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Tumble dryer belt servis m2010
Hi,I am trying to fit my new belt and cannot get to the bottom screws to take the front off, please has anyone got any suggestions, thanks
Mar 20, 2012 | Dryers
I have a Bosch tumble dryer but no instruction manual, please can you e-mail one on whittaker98@btinternet.com or post one to me at 2 Georgian Court, babbacombe Road, Torquay TQ1 3TF. Thank you. Lynn...
Our Bosch WTA2000 tumble drier dries the washing properly but is very noisy. How do we know what to replace, eg a belt, or whatever please?
Julie Welt
Mar 08, 2010 | Dryers
How to fit a belt for a indesit dryer ISL70c
Hi
Thanks for using FixYa. Please follow the step-by-step procedure---
1. Remove the front panel.
2. Reach underneath drum and behind motor to locate idler pulley. Push idler pulley to left to release drum belt tension. Remove the belt from the motor pulley.
3. Remove the drum and belt from the cabinet.
1-- Prepare for replacing the dryer belt by lifting the lint-screen cover on the top of the dryer. Then remove the lint screen. Skip this step if your lint screen is inside the door. Remove the 2 Phillips screws inside the door instead.
2-- After removing the lint screen, lift the cover and remove the screws that hold the lint-screen housing to the dryer top.
3-- Slide a putty knife between the front panel and the top near a corner. Lift the corner and repeat on the other side.
4-- To remove the lower panel, insert the putty knife between the panel and each side. Then twist to release clip.
5-- Place a few wood blocks under the drum. These support the drum when the front panel is moved away from the sides.
6-- Loosen the screws that secure the bottom of the front panel to the dryer sides. Do not completely remove the screws.
7-- Remove the screws that secure the front panel to the dryer sides at the top. These are accessed from the inside of the cabinet.
8-- Lean the front panel away from the sides and slip the new dryer belt over the drum. Then re-secure the front panel.
9-- Check that the lip on the back of the dryer drum fits properly against the seal on the rear bulkhead of the dryer.
10-- Locate the original position of the old belt, and slip the new belt in place. Keep the grooved side of the belt down.
11-- Push the idler pulley toward the motor and loop the doubled-up belt around the idler pulley. Slip belt around motor pulley.
12-- Rotate the drum counterclockwise a few turns to check belt tracking. Then replace remaining components and test run.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 20, 2010 | Washing Machines
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
Cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
May 01, 2009 | Dryers
Need to know how to replace the belt on my dryer
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Frigidaire FDE336RE Dryer
Zanussi tumble dryer. no.TC7114W
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
Aug 07, 2008 | Zanussi TC7114W Electric Dryer
New Starview Codes
00 2F EE 05 09 A1 46 E7 BA
01 FA 4B 82 4C 6D C8 EA 8C
Jul 01, 2008 | StarTech.com StarView SV211K 2-port KVM...
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
