Question about Compaq Presario 5000 PC Desktop
Compaq 5000 how to change hard drive
How to change hard drive
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 65 Answers
Is a long procedure ......
if u available online than i can help u by telling u d procedure.....
i cant tell u now becaz if i tell u procedure n dere is some error occurs then hw could u solve it....so it is needed to be online both of them....
Posted on Jun 22, 2008
5 Suggested Answers
  • 36 Answers
SOURCE: compaq presario 5000 hard drive erased
should of come with your computer
Posted on Jan 23, 2009
  • 4088 Answers
SOURCE: i am trying to find were to put the new hard drive
If this is to replace the original drive, you will find it behind one of the blank plates on the front panel. Remove the side cover and the power cord. You should see the drive at once. Remove the 4-pin power plug and the wide data plug. Remove the mounting screws (2). There is facility to place 2 more on the other side as well, but it is hard to get to, so there are usually none installed. Mount the new one in it's place. Install both plugs. It will need formatting which is done when windows is installed. You will also have to first go to 'setup' bios to confirm the drive--exit and save. If this is to be a second drive, go through the above in one of the vacant slots and find the extra power and data plugs. Confirm the 'setup' in bios as before, then let windows format and partition the new drive. It should automatically assign the new drive letter. Hope that helps.
Posted on Aug 21, 2009
  • 623 Answers
SOURCE: Removing the Compaq Presario 5000 Hard Drive
http://www.lapzone.com/catalog/410054-001.jpg
Try the link above for what it should look like.
Posted on Jun 16, 2010
kasi4it
  • 144 Answers
SOURCE: how do you remove a hard drive from a compaq
remove all the cables and the power line, remove the bolts from either end and then remove the Hard drive
Posted on Sep 16, 2010
Is a compaq presario 5000/8000 quick restore cd compatible with a compaq presario 2175us laptop?
I guess not. Drivers for compaq presario 5000/8000, are not the same as those for a compaq presario 2175us laptop. Now, actually that "notebook" looks to me rather outdated. You won't lose anything by trying. Worst case, format hard drive and install Windows XP SP3. Try to search internet for missing drivers.
May 15, 2015 | Compaq Computers & Internet
How do i re install windows xp on my compaq presario 5000
If you place your XP OS disc in the DVD/CD drive and boot from it, let the OS disc format your hard drive and there you are, when it has finished, all done. XP on your hard drive.
All you have to do then is try and find the drivers you need. Good luck as XP is no longer supported.
Feb 14, 2011 | Compaq Presario 5000 PC Desktop
Compaq 5000 push power button starts up shows loading windows then stops light stay on but will not boot. Replaced hard drive no help.
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 02, 2010 | Compaq computers10: Proliant 5000 CPU Card
How do you remove a hard drive from a compaq presario desktop 5000?
Sep 16, 2010 | Compaq Presario 5000 PC Desktop
Compaq logo
It appears that the hard disk drive is not being seen in the Bios. Ensure that both the power and data cables are connected to the drive and the controller. try booting again.
Jan 24, 2009 | Compaq Presario 5000 PC Desktop
Error loading operating system
If you take a hard drive for one computer to another the windows wil have to be reinstalled as windows looks at the hardware configuation and if it doesn not match, will not run. If the 20 gb hard is working , reinstall it then using backup software back it up to another hard drive.That will work. Personally I use" Acronis true home" software to change a hard drive but their  are other  wil also work. Some  backup and transfer softwware even come with the replacment hard drives.
Dec 10, 2008 | Compaq Presario 5000 PC Desktop
Swapping a hard drive
 You should be able to use that Hard Drive in the Compaq. Once transferred, you might be have to download the drivers to make sure all your devices work. I would recomend that you format the drive and reinstall windows.
Nov 01, 2008 | Compaq Presario 5000 PC Desktop
Ide issues
create partiion and format hard drive.
Mar 06, 2008 | Compaq Presario 5000 PC Desktop
Help on my compaq
do you have data on the hard drive... if not I will suggest a reformat of the hard drive and do a fresh installation... if that fails then check if your hard drive is a good one....I hope your boot sector is not damaged
Jan 07, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
