Hot tub wiring
I have an older model Spa Tech hot tub..I've hooked it up, but it won't respond...There is one brown wire coming from the GFCI unit that isn't hooked up..that's the only thing that I can see wrong...I need schematics or wiring diagrams or something..it's a model# ST650 - RLP
This has nothing to do with computer speakers. it is a hot tub wiring problem...
Posted on Jun 23, 2008
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
Balboa spa user manual
Unless it's a 110 tub, you don't. If the system is designed to run on 220 the circ pump and flow pump will not function properly, the power pack may not function and the tub will never reach temp. If it is a 110 hot tub I would still suggest having a licensed electrician run the line for you. Most insurance companies will not cover any type of hot tub related claim unless installed by licensed tub tech/electrician. If you insist on wiring it yourself, the BLACK wire is the "hot" wire carrying the current. In 220 installations the RED wire is the second "hot" wire. The WHITE/GREY is the neutral wire, and the GREEN is the ground. But again, I STRONGLY recommend paying the $80-$95 bucks to have it done professionally. I hope this helps =)
Nov 03, 2013 | Pool & Spa
Are the timers on the Hessco tub and spa hooked up as 220 or 110
Is this a spring-wound timer?
You rotate the timer knob, and it begins ticking?
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
http://waterheatertimer.org/images/Woods-spring-wound-277.jpg
This type mechanical timer will work with any voltage.
What voltage line do you have?
240Volt has 2 hot wires. Connect 1 hot wire to timer. Timer turns off 1 hot wires, and that action will turn off 240V circuit.
120V has 1 hot wire. Connect this hot wire to timer, and it will turn off 120V circuit.
Be sure you have GFCI breaker or Arc fault breaker on spa circuit.
http://waterheatertimer.org/How-to-wire-Arc-Fault-breaker.html
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
Add a comment with more information for best possible answer
Apr 26, 2013 | Pool & Spa
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
Apr 18, 2013 | Pool & Spa
Jacuzzi hot tub, Water is too hot. Heats until it trips the system. I have replaced the analog temperature control,
1) Safety question first
Why hasn't the GFCI tripped.
If your spa is not protected by ground fault., then you are at serious personal risk.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
2) Replace the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) If element is cracked, it can continue heating to ground wire, causing runaway heating.
This applies to spas, and water heaters of all type.
Dec 08, 2012 | Jacuzzi Pool & Spa
Can it be put on a timer so it won't come on so often
Yes.
If spa plugs into ordinary outlet, then choose heavy-duty outdoor timer. Use P1261 with GFCI or P1121 without GFCI.
If outlet already has GFCI, do not use two GFCIs
http://waterheatertimer.org/pdf/Intermatic-P1100-series-sell-sheet.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#P1261
If spa is hard-wired, then install T101 for 120volt, or T104 for 240Volt
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#T100-series
Oct 28, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
Hot tub trips gfci
spa may be leaking water internally check to see all grounds are hooked up . or you might have a bad gfic
Sep 06, 2012 | Qca Spas Pool & Spa
Hooking up a Hot tub
Everything above tells me this is 120V unit...if thats the case a single pole breaker is sufficient. Also by what you have written, a 15 amp breaker should suffice.
Jun 22, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
888 people viewed this question
 Grubhead
Grubhead
