Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite quiet pak 9 dryer
Dryer does not complete cycle. It turns off prematurely, leaving damp clothes, with error message E1.
  • 3 more comments
  • ivymck Jun 23, 2008
    dryer comes on and then stops after 10 minutes and error message appears.
  • blondetwyn67 Jun 27, 2008
    We recently moved into a home we purchased and along with it came the Kenmore Elite Washer and Dryer. The dryer model is: 110.94832201. I am having the same problem with the dryer stoping in mid cycle and displaying the code: E1. I have no manual on the dryer therefore no knowledge on anything about the dryer other than a "quickstart" manual that the sellers left behind for me. Any information on this would be greatly appreciated!
  • Anonymous Jun 29, 2008
    I have the same problem with my dryer. It runs for a little while then displays the E1 error message. the dryer really never has worked right from the beginning. It is supposed to have a moisture sensor, but it has never worked correctly. Do we have to call Sears to have the thermistor replaced, or can we buy the part form someone and replace it ourselves? Help!! I hate this dryer, but can't afford to replace it.
  • Anonymous Mar 12, 2014
    Get f 23 error code
  • Anonymous Mar 28, 2014
    clothes still damp after cycle and sometimes dryer does not automatically shut off
  • 413 Answers
Error message E1 indicates the temperature thermistor has failed.
Posted on Jun 22, 2008
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
I also have a Kenmore Elite Smartheat quitepak 9 HE4. It takes forever to dry in the Auto modes and it still leaves them damp. However the Manual modes dry great. I suspect the Auto modes has some kind...
if its a condenser dryer for some unknown spastic reason we have come across some where 80% of the settings didn't dry the clothes we then found out this how they were suppose to work (dont ask me why still havnt figured that i think it was something to do with ironing and not needing to use steam because they are already damp yeah i know doesnt really make a whole lotta sense to me eitha), you need to look up what cycles actually do what as i found only manual and 1 other setting actually completely dyed the clothes
Feb 09, 2011 | Kenmore Elite HE4 Electric Dryer
My Kenmore elite HE4 quiet pak 9 electric dryer is working, but it emits a constant series of 3 beeps, and sometimes shuts off before the cycle is complete. I have to unplug it to stop the beeping....
You are getting moisture in the control panel buttons. After a while the panel will not function at all. The light in the dryer tub will still come on when the door is open. When you unplug your machine and it sets for awhile you are allowing the moisture to dry and the machine can reset. Some people use a hair dryer to dry out the control panel for a temporary fix. Eventually, you will have to get it replaced once it stops resetting for you.
Oct 25, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
975 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
