Out of 4 networked computers, 1 computer has stopped networking, and the light on the Linksys for computer #3 confirms this because it's light is out. How do we fix this?
  • 1,314 Answers
It could be one of two issues. The cable has gone bad. Replace the cable. Or, the LAN port on the computer has gone bad. Replace the LAN port. If it's a built in LAN port, just add a PCI one; they can be purchased for under $10.
Posted on Jun 22, 2008
My linksys network switch is not connecting network computer, what can i do to get it back to work?
Do you have any activity lights on the Linksys? If not your switch has no power a hardware problem. Try to power off for 5 seconds and restore power on the Linksys unit. Try to shut down (do not restart) all computers. Are all the activity lights off? If not again power off the Linksys for five seconds and restore power. Power on the computers and verify the activity lights are now green for each computer. If the computers are not networked and the activity lights are green, check your network settings on your computers, which could have incorrect TCP/IP settings or workgroup. If one activity light is not green for that Ethernet connection, check your cable connection or replace the Ethernet cable. The workgroup should all be the same name. The TCP/IP address should be the same with the exception of the last set of host digits which should be unique to each computer address.
Jul 27, 2010 | Linksys SR224 24Port Ethernet Switch
I am currently using a Linksys BFR series router that works fine. I am trying to replace it with a Linksys WRT 300 N router. I go through the installation program provided by Linksys on my HP computer...
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | Linksys WRT300N Wireless Router
Router QoS / prioritize internet usage on a network ??
i can confirm that QoS is in D-link DIR-615 router [newest firmware. i use it myself and its great
Sep 13, 2009 | Linksys Wireless-G WRT54G Router
Network adapter not being recognized by pc
you need to disable the old network card go to the computer setting (CMOS) and disqble the network card (you are having a hardware addressing conflict.
Jul 01, 2009 | Computers & Internet
Use Incoming Wireless to Send Out Ethernet *Internet Sharing*
Enabling ICS
To enable ICS, on your host computer:
1. Open Network Connections by clicking the Start button , clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage network connections.
2. Right-click the connection that you want to share, and then click Properties. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
NoteThe Sharing tab will not be available if you have only one network connection.
4. If desired, you can also select the Allow other network users to control or disable the shared Internet connection check box.
5. Optionally, to allow other network users to use services running on your network, click Settings and select the services you want to allow.
When you enable ICS, your local area network (LAN) connection gets a new static IP address and configuration, so you'll need to reestablish any TCP/IP connections between your host computer and the other network computers.
To test your network and Internet connection, see if you can share files between computers and make sure each computer can reach a website.
Once you have done the above, connect the Ethernet cord to the WAN/Modem port on the Linksys router and set the router to Dynamic IP. Then connect another computer to one of the LAN numbered ports on the router and they will have internet. Remember your computer MUST be on for the computers connected to the Linksys to get internet.
Jun 26, 2009 | Acer Windows Vista TL-562G Notebook
Everytime I try to connect using the WUSB54GSC it
You need to Update the Drivers for your Wireless Adapter...Download the Drivers from here
After downloading the drivers you need to unzip the file...After you unzip the file you should un-install the adapter drivers/software from Programs menu...Leave the adapter connected to the PC and reboot your computer...Once the computer is rebooted you should see a message "Found new Hardware"...Select the option Install it from a specific location and click Next, then select Include this location in Search and browse to the place where you have unzipped all the files and select the Driver folder and click O.k...Then click Next and it should install the adapter drivers...
NOTE : This installation doesn't install the software(Linksys Monitor)...
Once the Adapter is installed, Click on the Start button >>> Control Panel >>> Network Connections- Right click on the "Wireless Network Connection" icon and select "View Available Wireless Networks"- If you see your wireless network in the list, highlight it by 'single' clicking on it- Now click on the 'Connect' button below- If your wireless network is secured, it would ask you to provide the network key- Provide the wireless network key and confirm it again in the confirmation box and click "Connect"...It should connect to your Network and Internet...
Jun 16, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Blinking power light no connection
Try this :
If the Power LED is flashing, then power off all of
your network devices, including the modem, Router,
and computers. Then power on each device in the
following order:
1. Cable or DSL modem
2. Router
3. Computer
Apr 03, 2009 | Linksys WRT350N Wireless Router
Failed connection - Linksys Compact Wirless-G WUSB54GSC adapter
1.uninstall the driver
2.restart computer.. the the cd driver of WUSB54GSC and that..restart computer... the windows..insert your linksys usb wireless device...and start using your wireless..
Jan 04, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
