Question about Sony KP-57HW40 57" Rear Projection Television
Television is seperating and distorting colors
Example: a line of text will appear normal but will be duplicated in blue curving partially below the original.
Most images on the screen will have yellow or blue "shadows."
  • scottjustin Jan 13, 2009
    the station symbol ( cbs eye, nbc peacock) there are two of them one red and one blue...ine the middle isnt bad except you can see all colors around everything, and the top left and bottom right of the screen have no colors and lines through the picture the top right and bottom left have pefect picture and then from there it progressively gets worse (as in outlining in all colors)...before all of this happened i would turn on the set and it would slowly turn to a complete blue screen and i adjusted it with the knobs behind the speaker cover...could that have a had a affect on the screen doing what it has done now?
  • Anonymous Jan 17, 2009
    I have the same situation.  Yesterday the KP-57HW40 worked fine and last night it appears as if the colors are slightly off center.  I have shadowed colors on the left hand side of the set where the items on the set are doubled up in two colors, slightly separated.  Not sure how to adjust or what to do about it.
  • 1,512 Answers
Heyitsbob
Sounds like you have a convergance problem You could go through the adjustment procedures in the owners manual. I can get one if you dont have a copy.
But if it just started out of the blue, something hase failed in the set and you will need to get a technician to have a look at it.
It is not a faulty tube... sheesshhh
regards
robotek
Posted on Jun 22, 2008
  • Graeme Ross
    Graeme Ross Jun 22, 2008
    You can make enquiries for support at Sony's website here
    Of course, if you are up to it, I could talk you through the repairs needed. I must warn you that there are dangerous voltages inside the set that can injure or kill you. Getting a tech to look at it is the best bet.
  • Graeme Ross
    You can download an electronic version of your user manual here
    On page 33 it has details of how to do a "flash Focus" which is an automatic procedure for setting up your convergance. Flip open the front panel and press the "flash focus" button. Let me know what happens
Could someone send me a copy of the service manual at wsimpson@controlssupport.com
Posted on Aug 06, 2008
    Master:
  • 848 Answers
There is some problem with your picture tube
  • gopinath pasupathy Jun 22, 2008
    if you dont have problem with your picture tube try this
    That looks like retrace lines. Anyway, you should try to adjust screen pot not focus pot. Make sure you are turning blue screen pot (there are 3 focus pots and 3 screen pots) and do it slowly. If you turn it too much, it will affect your grayscale
Our e-Studio 45 printer is printing duplicate text / images. Looking at the print out, it looks like a duplicate of what is being printed slightly below the original text or image. Looks like a ghost layer...
Some printers have a maintenance option to clean it. May need to manual clean the drum or rollers but follow the instructions or could damage components. Might need to check drivers are up to date. Are you using a different type of paper? Is the paper feeding correctly? Are the rollers catching/sticky? Is the toner/Ink old or almost out?
Jan 06, 2015 | Toshiba e-Studio 45 Black and White Copier
Duplicate image in pink displays on the screen.
From your description, it sounds like an alignment problem. There are 3 LCD panels in the projector. Each one displays an exact duplicate image of the others except it's either red, green, or blue. Under normal conditions, the images precisely overlay one another so you get a sharp image. Due to age, heat, or vibration/shock(impact) it would appear that the red LCD panel has shifted a little, giving the "ghosting" effect. You'll have to have the unit repaired by a qualified tech. He'll have the special electronic equipment needed to align the panels properly. Before sending the unit in, try a reset in the menu. Sometimes, the projectors can shift the image electronically, using math algorithms which will try to auto-sharpen the display. Hope I was able to help!---Rick
Aug 11, 2009 | Sanyo PLC XU35 Multimedia Projector
Hitachi 46F500 and there is a blue curved bar
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Hitachi 46F500 46" Rear Projection...
3-d like picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 14, 2009 | Hitachi 57F500 57" Rear Projection...
Shadow images and scrolling banner curves upward and back down.
  • Screen looks 3D
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Double Image Red and Green
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
WS-55807: Images are dark on right side of display, but will go away after 3-4 hours.
you could be on the right track get some freeze spray and go around all the parts to see if you can make it act up, same with heatgun or hair dryer when first turned on heat one area at a time to narrow your problem down
Oct 21, 2007 | Mitsubishi WS-55807 TV
Descending curved line on screen
if the tv has a portal on the side open it up and make sure the screen is not out of it's track, don't set anything on top of the set it could make it happen also
Apr 13, 2007 | Samsung HCN653W 65" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
