Question about LG WM-1832C Front Load Washer
Washer door latch
Got a DE error, then replaced the door latch assembly. It tries to lock, but will not engage. I also changed the pressure switch IE error because the water filled enough to blow open the door. connections are good why wont it lock.
  • 1 more comment
  • dirty jersey Jun 24, 2008
    I have been doing service for over a year with every name app. but I'm stuck, even my boss don't understand. please help or it looks like I'm buying a 1200$ machine. @#$$
    i even had a hand held door shaft and it still will not lock on to that
  • Anonymous Mar 23, 2014
    EMZ 38.0140 461970200691 Latch Lock Switch ASSEMBLY
  • 2,071 Answers
It seems the microswicth inside is defected,this automatically switch when its works ,checked this out and also the alignmet of latch ,,I give a site for more information..
http://www.cuisinart.com/manuals/index.php?item_id=34
Posted on Jun 24, 2008
    Genius:
  • 1,665 Answers
Enter model number at search tab- Select Door & Handle components at "PartType"
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
  • 6,487 Answers
Try this one:
Unplug the washer.
Remove the bottom panel.
Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
Located on the bottom of the door latch assembly is a tear-drop shaped tab.
Gently pull the tab down about 1/4" or until a click is heard.
You may have to replace the door switch assembly.
Hope that helps..........
    Guru:
  • 1,894 Answers
The door latch may have gone bad
test it by pressing with some sharp object like pen
  • dewan nafees ahmed Jun 24, 2008
    does the error stop when u press the door latch with a sharp object like a PEN?
    and doing a hard reset must have removed the error.
    if the door is still not locking the new door latch is not the right one for ur machine i think.
    have a cross checks on that
    Genius:
  • 3,422 Answers
Unplug your machine, remove the top panel, doublecheck all of the wiring is securley connected. Sometimes the wiring becomes loose due to the machine's vibration.
De error message on wash machine
For LG washers, the DE error indicates a problem with the door lock. If you just started the cycle and the error occurred, then the door couldn't lock properly. (The machine turns off and indicates the error so that the water won't flood your laundry area.) First check if there are any clothes between the door and the frame. If needed unplug the washer for 5 minutes. Then restart the machine try to open the door. If you pressed Pause, wait a minute or two. If the error occurs at the end of the cycle, it may not be unlocking properly.
The latch mechanism may have failed or the PTC sensor in the latch has failed. The entire latch would need to be replaced. Here's one: http://www.appliancepartspros.com/lg-door-lock-switch-6601er1004c-ap4441836.html . If the door locked failed with the door closed or the washer is under warranty, contact LG or a repair professional for service.
I hope this helps.
May 18, 2015 | LG WM2688H Front Load Washer
How do i fix an LG 5.0 fuzzy logic washer that keepscoming up with a DE error?
The DE error indicates a Door Error condition....check out the door for any distortion or misalignment with the door latch.
Check the door latch assembly for continuity and if faulty replace the switch.
Mar 24, 2015 | LG Washing Machines
DE error code on LG washing machine
Beyond that could just be the door latch itself.
Nov 23, 2013 | LG WM-2277HW Front Load Washer
Please Help! My LG WD-3274RHD has the error code "dE" after replacing assembly door switch?
dE for LG does the spring of latch hook actuate? no> fix door latch Yes> is there clicking sound once or twice when the start/pause button is pressed to start the cycle? No> check door switch and main PWB Assemblyhope that helps..
OE is Drain Error.
Sep 02, 2012 | LG WD-3274RHD Front Load Washer / Dryer
44082 is the model #
he code "dr" means the control doesn't see the door switch being closed.This can mean the door catch is broken or the door is bent and not shutting all the way or clothes are preventing the door from shutting all the way but most likely it means the door lock assembly needs to be replaced.
Check the door strike is not broken and make sure the door is shutting evenly. If the door is shut fully and the "dr" error keeps occurring then replacing the lock assembly 131763245 will most likely fix this problem.
The switch can be obtained from the following link: Sears PartsDirect . Remember to unplug the washer first before attempting to change the switch.
The image below contains the instructions to access and change the latch. Changing the latch is easy the tough part is putting the spring back on. Sometimes it helps to have two extra hands when trying to reinstall the wire/spring.
I hope this information helps you resolve this problem but submit another question with any additional details for further assistance.
Helpful attachments:
The code "dr" means the control doesn't see the door switch being closed. This can mean the door catch is broken or the door is bent and not shutting all the way or clothes are preventing the door from shutting all the way but most likely it means the door lock assembly needs to be replaced. Check the door strike is not broken and make sure the door is shutting evenly. If the door is shut fully and the "dr" error keeps occurring then replacing the lock assembly 131763245 will most likely fix this problem. The switch can be obtained from the following link: [Sears PartsDirect |www.searspartsdirect.com] . Remember to unplug the washer first before attempting to change the switch. The image below contains the instructions to access and change the latch. Changing the latch is easy the tough part is putting the spring back on. Sometimes it helps to have two extra hands when trying to reinstall the wire/spring.
Apr 15, 2010 | Kenmore 43042 Front Load Washer
Dl error- washer won't turn over to start the cycle
dl error refers to " Lock Error ".
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Fails
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
Whirlpool ht duet still getting F dl error
DL= Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
Potential Causes
• Door Lock/Switch Assembly Failure
if you have done all the abovet the CCU must be bad
Aug 28, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Door latch
DE error code is because there is a drain problem and it will not lock the door.
Jun 24, 2008 | LG WM-1832C Front Load Washer
DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Oct 23, 2007 | LG WM-2032H Front Load Washer
LG WM-1832C Front Load Washer Logo
378 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
