Question about Garmin nuvi 250W GPS Receiver
Nuvi 250w Locks up @ Main Screen tried Master Reset Still doesn't work. Tried to plug into computer but Puter doesn't See it any Ideas PLEASE need it for work
Call Garmin is what I have been told to do
Posted on Jun 23, 2008
Hy my name is mariana i bought a sd card for my garmin 205w nuvi and when i plug it in to the garmin it doesn t show nothing on the screen i ring the company and they said me that i need a code to unlock...
Have your tried restarting the Nuvi 250W with the SDCARD inside? If there's something on there (like a map or custom POI's) it comes with a question if you want to install it on your Garmin GPS.
If nothing pops up - the card could be empty. To check that connect your Garmin to a PC/MAC. It should go into PC communication mode.
Then the SDCARD shows up on your computer as removable storage. Click on the removable storage drive (which is the SDCARD) and see if something is on there. If its empty it would explain the behavior you describe.
If there's a Garmin MAP on there it be detected upon startup of the Garmin and should start the installation process after asking you.
Jul 12, 2011 | Garmin nuvi 250W GPS Receiver
I have a Nuvi 250W and it can find locations already in the unit but it will not take a new address and it locks up when i push State. i really want a map update with the hope it will fix my problem....
It's unlikely that updating the map will solve the problem. You could try updating the software. Download webupdater from and when it's installed you'll get an option to update the satnav software. That may solve the problem. Or you could try to reset the satnav back to how it was when it left the shop by pressing the bottom right corner of the screen as you turn it on. However note that you will lose your saved locations if you do that. I hope this helps.
Jul 27, 2010 | Garmin nuvi 250W GPS Receiver
My Garmin nuvi 250W GPS is NOT powering on.
try connecting it to your computer via the usb cable. that may reset it. outdated maps will not cause this problem.
Feb 21, 2010 | Garmin nuvi 250W GPS Receiver
Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Feb 05, 2010 | Garmin nuvi 250W GPS Receiver
I leave my nuvi 250w plugged in to the cig lighter socket and it normally starts up as soon as i turn on the ignition. now it wont start up at all, is there an internal fuse inside it??
try charging it with the usb cable to your computer for a few hours, then try and start it again.
if that fails, try a reset
note: the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
hook up the nuvi to the web updater and get the latest update
you can get the Web Updater HERE
Nov 06, 2009 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 250W stuck on "Loading Maps..." screen. I know it wasn't a clever thing to do, but I dragged a file (a map i think) into the Nuvi's internal memory via Windows Explorer. Now every PC i have...
Try the reset, and if that fails, download the web updater from the garmin site and try that route.
Master reset will erase all way points or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
Bill 39c203c.gif Learn from your failures or you will fail to learn.  Theory: you understand why it should work but it doesn't
Practice: it works but you have no idea how
   ALL That is necessary for the Triumph Of evil is That good men do nothing.
Aug 30, 2009 | Garmin nuvi 250W GPS Receiver
My garmin nuvi 260w wont turn on. I used a charger that it wasnt used to and the whole thing just shut down. It wont turn on i tried the origanal charger, i tried pluging it into my computer, i even tried...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
May 31, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Won't stay on
Have you installed anything lately? Do you have any sd card installed? Usually this is the cause for it to crash. There is a reset on the bottom of the nuvi, when it locks up blank, press the reset button and see what happens...
Jul 07, 2008 | Garmin nuvi 250W GPS Receiver
NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
May 24, 2008 | Garmin nuvi 200W GPS Receiver
Nuvi 250w alphabet problem: no "E" nor "R"!!
I checked the garmin website to see if there is an update. Didn't see one. But I'd try the web updater just to make sure. BTW there is a little reset button on the bottom you could try if it goes flaky again
Mar 02, 2008 | Garmin nuvi 250W GPS Receiver
Garmin nuvi 250W GPS Receiver Logo
176 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
