I have a eureka capture and I can't figure out how to get into the machine to change the belt
Lie the vacuum down so it's completely flat, the back of it facing up. On the bottom of it, on the grey plastic, there are instructions. They say, to access the belt, remove the screws numbered 1, 2, 3 & 4. Then look at the four corners of the bottom of the vacuum and you'll see these numbers. You may need a flashlight to actually see the screws because a couple of them are pretty deep inside the plastic. Loosen them with a long shafted, Phillips screwdriver. Stand the vacuum back up and the screws should just fall out. Then you can easily pop off the cover to change the belt.
There 2 or 3 screw on the top cover to remove, then it comes off. Then you can get to the belt, inspect the brush roll while you have it out, make sure the ends move freely.
How to change the belt
