TV turns on, then immediately off again
Whether I use the remote or the button on the TV itself, it is only on for less then a second before switching itself back off again. The only troubleshooting suggestion in the owners manual that applied said to unplug it for an hour and try again. I left it unplugged for a day and tried, but still didn't work. I see another problem on here that might be the same, but the reply was way to technical for me. Can anyone offer any help, or should I just go get a new TV? my jvc tv power on and off. its just a second when i open the tv using button or remote its suddenly off and on again always on and off. how to fix this problem? when I turn the tv on, it turns itself off immediately try to turn tv on it turns on shows a blue screen then turns off after 2 seconds
  • 1 more comment
  • Anonymous Nov 29, 2008
    makes me crazy, same thing
  • Anonymous Mar 30, 2014
    TV wont turn on. Unplugged it and left for a day. It then turned on but when I turned it off again it wouldn't turn back on.
    GVA TV wont turn on. Unplugged and left for a day. It turned on but once off will not turn on again
  • 260 Answers
Hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
Posted on Jun 22, 2008
Wat i do is i turn it on as soon as the blue screen comes on i keep my finger on the prog - button until the writing in the top corner goes off then the tv stays on note all buttons pressed r on the tv not the remote
Posted on Jun 25, 2008
TV switches off automatically.
if you take the cover off, then take a look at the capacitors.
check if any have bump ..
Jan 13, 2014 | LG Televison & Video
I have a Flat screen LG TV, 26LG3000, I cannot turn the tv off from the remote or the button on the tv itself when I try to do this the tv will go off but then after a few seconds will come back on again....
Its because you tv is set to automatic turn on ! To avoid this ! When you switch off your tv remember to plug it out from the electricity board !
Oct 15, 2013 | Televison & Video
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
Can you help i have the asda rch7h10 smart price remote controls and have lost the insrutions i changed the battries and now they need re programing
Switch the TV on.
Press the Set and TV buttons together and the red LED should light continuously. Then press the power button and then press it every time the LED flashes (about once a second).
When the TV switches off, press the TV button on the remote. Switch the TV on with the remote and check that the other buttons work as expected. If not, repeat the process...
I had the same problem: worked it out by trial and error ;-) Hope it helps...
Oct 28, 2010 | Televison & Video
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
Tv shuts off immediately
check first for the contact point of your control panel button maybe the tact switch is shoted specially when your always using remote control for function operation.second check power supply for leak capacitor or change in value,check also the photo coupler for leak test or change in actual.
Aug 01, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Can not turn off power lock
hold volume up and menu buttons at same time for 10 seconds - under left edge of tv
Jun 15, 2009 | ViewSonic N2230w 22 in. LCD TV
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
The flyback transformer are damaged.
May 26, 2008 | RCA TruFlat 27F520T 27" TV
its the technical problem, the switch it my be hold in or[stuck]or try to see experts near you.
Nov 02, 2007 | JVC AV-36260 TV
Televison & Video Logo
1,876 people viewed this question
Top Televison & Video Experts
