Question about Protron PDV-768 Portable DVD Player
3.5 mm av cable for proton pdv768
I need a cable to connect the monitor to the dvd, the cables i get have a shorter jack than the original. where can i find the correct cable?
  • Protron Master
  • 1,550 Answers
Go to radio shack maybe there you can find it.Good luck
Posted on Jun 22, 2008
Im having trouble hooking up my sound bar to my monitor E196FPf
As far as I know, the E196FPf monitor does not have speakers or an audio out. Thus you'll need to connect the sound bar to the audio out of your computer or other source. On a laptop, this will be the headphone jack. On desktops, you use the lime-green 3.5 mm jack on the back of the system.
Depending on the sound bar, you might need a Aux (3.5 mm M to 3.5 mm M) cable, a 3.5 mm M to dual RCA (red/white) adapter cable or an analog to digital audio converter with the 3.5mm to RCA cable and appropriate digital audio cable.
Please add a comment with the model of the sound bar and the audio/video source, if you want more information on the best solution for your application.
I hope this helps.
Aug 07, 2016 | Computers & Internet
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Jul 15, 2008 | Televison & Video
I cannot hear any sound from my Dell monitor 1702FP. Are there speakers installed within the monitor?. VGA cable is connected. When I use a spare monitor using the VGA cable the sound is loud and clear. ...
The Dell 1702FP doesn't have speakers.The specs of the Dell 1702FP are available here: . (BTW neither does the Dell 1704FPT.) However, some Dell monitors can have a sound bar (speaker set-up) mounted on the monitor.
VGA cables don't carry sound. Check if a second cable (an audio patch cable is connected to the computer and the second monitor). (There are some cables that actually bundle the 3.5 mm patch cable with the video cable for convenience. (I've seen a number of DVI cables with that bundle option.) The plugs will separate into separate units at each end.
Other monitors do have speakers built in - look for a 3.5 mm audio input jack with the rest of the input connections on your monitor. There are some monitors that accept an HDMI input with a 3.5 mm audio out jack; these monitors don't have speakers and thus are enabling a daisy chain to connect the speakers to the monitor. So you do need to be careful and look for the audio in label.
You can attach a set of speakers to your computer using the audio out (look for a lime green 3.5 mm jack on the back of a desktop). For laptops or to use the front audio ports, look for a headphone jack.
I hope this helps. Please add a comment with more information about your monitor and computer for additional assistance.
Mar 11, 2012 | Computers & Internet
What cables are needed to connect soyo dylm2286 so that monitor speaker works?
For the speakers to work on your monitor you need a unexpensive cable that has on each end the same type of connector: 3.5 mm stereo jack. It is the same type of jack as on e.g. headphones.
The cable must be connected between the green output jack from the PC to the similar connector on your monitor.
Please let me know if it helped.
Aug 10, 2011 | Soyo DYLM2286 Monitor
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I am wanting to connect my portable wharfdale dvd player to a tv. where can i get the right connection cable. thanks
Usually somewhere like radio Shack will have those cables, they are called AV, Audio Visual Cables, You need 3 Cables, with "Male Jacks" at both ends, usually Red & White, (The Audio), & Yellow, (Video). They connect color to color at each end, and on the TV you select "Aux", "Extern", but NOT a channel. If you have "Component Video, then you will need a set of 3 & 2 cables, (5 all together) Blue, Red, Green, ALL Video, & White & Red, Audio. you select the "Input" on the TV the same as for AV. So with AV, you use 3 cables, with Component, you use 5. If HDMI you need a single HDMI cable. cables.
Feb 21, 2010 | Televison & Video
Phillips television with av connections
that TV has no AV connection jacks. look for a converter AV to RF. the vedio and audio from your DVD player will be connected on the vedio/ audio IN and let your RF out go to a TV on RF IN, this will solve your problem. thanks
Jan 21, 2009 | Philips Magnavox DVD/VCR Dual Player
MDP-1815: can't get video on external TV using AV-Out
The AV is actually the yellow jack.
Just plug that in.
If it don't come up then you have to enable it in display options.
How you do that is click on the center of the laptop screen when the menu appears goto properties and then advanced you will see the settings.
Happy Holiday
Dec 24, 2008 | Mintek MDP-1815 Portable DVD Player
MPEG4 HDD Player
Connect your HDD Player to your Television (TV) or Monitor using AV Cable; your TV will become a full of AV Entertainment System.It is Capable of Downloading Files from your Computer,HDD Player can be act as your Mobile Hard Disk that Back-up your Important Files .It is Compatible with 2.5" IDE hard disk up to 500GB (not included)
vk1_3.jpg To computer :
Connect your HDD Player to your Computer using the USB2.0 output cable (cable provided); your HDD Player will become your External Hard Disk that will be managed by your computer Window Software ,Back-up your Important Files. But it need additional 2.5" IDE hard disk to work .
To TV or Monitor :
Your TV will become a full of AV Entertainment System after you connect your HDD Player to your Television (TV) or Monitor using AV Cable.Play movies,mp3 and view picture on TV directly,
vk1_2.jpg Specifications:
  • Compatible with 2.5" IDE hard disk up to 500GB (not included)
  • It support NTFS and FAT32 formats
  • AV out to TV directly, VGA out to Monitor
  • When connected to your Computer, Do not connect your Power Supply
  • When connected to TV,it need power supply ( included,and which is compatible with your country)
  • Displays digital photos and movies on a TV, monitor without the use of desktop or laptop
  • Playable programs: MPEG4, Xvid, Divx, DVD,SVCD, VCD, JPEG, MP3,JPEG picture and MP3 song
  • Portable HDD function: USB 2.0 interface, windows management, be convenient for your study work and entertainment
  • Key button and Remote control operation
  • Supports TV type: PAL and NTSC
  • Audio outputs: stereo 2-ch (RCA)
  • Supports OS: Windows 98/98SE/2000/ME/XP
  • Portable design :132 x 80 x 19 mm
  • weight:215g
In the package comes: 2.5'' HDD player,USB cable,AV cables,remote control,manual ,power supply
Jan 29, 2008 | Computers & Internet
How to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
Jun 21, 2007 | Denon AVR-886 Receiver
Protron PDV-768 Portable DVD Player Logo
103 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
