Question about Zanussi Dishwashers
I am trying to source a heating element for a zanussi dishwasher zdf221 and information on how to fit this part thanks
    President:
  • 1,462 Answers
If in uk, try currys partmaster mor you local service force dealer. don't know this particular model but should be easy to do. remove back and element is usually held in by 2 7mm nuts. disconnect wires from element, making a note of where they go. there is sometimes also a bracket inside the oven which holds the element up and this also should be removed
Posted on Jun 22, 2008
My zanussi dishwasher, zdf 301 isn't heating water so only running cold washes.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 03, 2011 | Dishwashers
Hi,i have a ZDT6053 but it will not heat the water,any sollutions
heatman101
Oct 25, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 6543 not heating water and not drying
heatman101
Oct 24, 2010 | Dishwashers
DE 6850 not drying
heatman101
Sep 16, 2010 | Zanussi 24 in. DE6850 Free-standing...
Zanussi de6850 not heating up
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Dishwashers
HI I HAVE A ZANUSSI ZDF221 DISHWASHER THE WATER WASN'T GETTING HOT ,SO I FITTED A NEW ELEMENT BUT IT IS STILL THE SAME ,ANY IDEAS WHAT IT COULD BE MANY THANKS ALAN GRIFFITHS
Hi the most likely cause is the electronic mounted in the control panel behind the progamme dial. there is a relay which can unsolder itself. you can try resoldering (use lead free solder). or change the electronic.
Aug 05, 2010 | Zanussi Dishwashers
Hi, my zanussi zdf221 dishwasher wont work, it makes a noise and constantly empties, any ideas please
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Jan 16, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
Dishwasher not heating Zanussi
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
lmnbv
Mar 30, 2009 | Zanussi 23 in. ZDi6053SX Built-in...
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Problems! zanussi zsf6120
You can check the heating element with an ohmmeter and it should read a few hundred ohms. Don't know about the thermostat but it should be inline electrically with the heating element and should ohm as a short when cold.
Nov 23, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Dishwashers Logo
143 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
