Question about LG Electronic Window Air Conditioner
Air conditioner will not start
Unit shut off and will not restart
Check power supply , breaker, air con switch,
Posted on Jul 27, 2008
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
Trip switch on air conditioner
this switch may be in the attic. i had similiar problem with my a/c and thats where the serviceman said my switch was.
Jul 27, 2012 | Carrier Heating & Cooling
Lg portable air conditioner shuts off and has an E1 error.
I think what you may be seeing FL , instead of E1. FL indicates that the water collection tank is full and needs to be emptied. That would coincide with the unit shutting OFF and not being able to restart it.
Turn the unit OFF and Unplug it, before draining the tank. Once the tank is drained and the unit is restarted it will revert back to cool at 77 degrees F. You can then restet the temperature to what you desire.
I hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
Room is warm 86 deg. unit runs, discharge temp is near 70 deg. unit runs for a while, will not bring room temp down.outside unit shuts off, i turn unit off, 1 hour and restart, it does the same.
The unit has a leak and is low on charge (freon) Find and fix leak, then vacuum and recharge...Leak is probably in flare fittings behind unit...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Mitsubishi MS24WN Air Conditioner
Amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jun 30, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
My Sharp Room Air conditioner (Mod.AF-S120FX-A) when it's starts
Most likely the terrible noise you hear is the compressor starting... Sometimes it is louder than when its runs continuous. Just make sure if the unit is shut off allow a few minutes for the freon to equalize before restarting the unit. Its possible that the Compressor is going out, But as long as it cools and the noise goes away after a minute or so, i wouldn't worry about it to much.
Apr 29, 2009 | Sharp AF-S120FX Air Conditioner
I have a 10000 btu window air conditioner and when it cycles off and comes back on the compressor seem to be starting under a load and blows the breaker
How long is the unit off before it restarts? These system are not designed to restart immediately after it shuts off. The system pressures need a chance to balance out before a restart is called for.
Jul 02, 2008 | GE Heating & Cooling
Carrier 38YRA-O24
Does this happen just when you shut it off and try to restart it immediately? If so it is trying to start against pressure that has not been given time to balance out. If this happens at any time the unit tries to start it could be low voltage or a hard starting compressor. They make hard starting kits for this purpose.
Jun 05, 2008 | Carrier 38CKC042 Air Conditioner
Machine shuts off
your control board assembly is faulty relace with a new one from your local appliance parts store
Sep 09, 2007 | Samsung AW1293L Air Conditioner
LG Electronic Window Air Conditioner Logo
117 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
