Question about Epson Perfection 4870 PRO Flatbed Scanner
Bliking red light.
I tryed the lock/unlock both wasy...plug and un plug..I'm out of ideas..is it posible I need a new bulb?
    Genius:
  • 1,689 Answers
Sounds like the 'transportation lock', check the lower left hand side corner of the inside the scanner cover and the left-back side
check this out:
http://files.support.epson.com/htmldocs/pr48ph/pr48phrf/maint_3.htm
so far it is not a sign of changing the bulb, plus replacing the bulb may cause more, but if in case, please try this out first.
Posted on Jun 22, 2008
My hp compaq nx7400 PC Notebook's screen got bliked after certain minutes again and again after i installed Mysql server 5.1. Anyone hava idea
It seems there is a conflict within that software and your notebook remove it and see if that fixes this issue. Not quite sure as to what your trying to explain. You can also do a rollback as well read up on the compatibility issues that you may face downloading this software to use in a Notebook PC. If you un-install the software and this fixes the issue make sure your downloading the correct version of this software or any software you wish to to use with your notebook. It is obvious to me that Notebook worked fine "Right" before you installed this software. John
Apr 22, 2012 | HP Compaq nx7400 Notebook
How do you replace the fog light bulb on 2008 avalanche
    • 1 Open the hood and reach down into the engine bay for the fog light assembly. If you cannot reach the fog light assembly from the top you may need to get underneath the truck to reach it. Remove the electrical plug running to the fog light ballast.
    • 2 Remove the bulb. Unlock the fog light bulb by turning it counterclockwise and pulling it straight out of the assembly.
    • 3 Slide a new bulb into the fog light assembly. The part number you will need for the new bulb will be located on the ballast or base of the old bulb.
    • 4 Turn the bulb clockwise to lock it into the fog light housing.
    • 5 Reconnect the electrical connector to the bulb ballast.
Jan 23, 2011 | 2007 Chevrolet Avalanche LTZ
Getting blinking "red light" , doesn't scan
There are a few reasons this might happen. 1) Check if the transport lock is in the locked position. Unlock the unit if it is locked.
2) An error occurred. Try restarting the computer, unplug the scanner, wait 10 seconds and reconnect the scanner. (This fixes issues where the software isn't running/fully loaded or the connection isn't solid).
Try a new USB cable and a different port. If you have a USB hub in the middle, try a direct connection. (Bi-directional communication is needed and this may show as an error if it is lost.)
3) Try unplugging the scanner from power and plugging it back in.
4) Try unplugging the optional accessories. If they fail, the unit may indicate a failure.
5) The lamp may need to be replaced.
6) Something else may have failed. Consider if it is worth having the unit serviced.
I hope one of these ideas helps.
May 16, 2010 | Epson Perfection 3490 PHOTO Flatbed...
Went to plug in. Green light came on, no heat.
it's posible to have a disconected wire or a heating element burned. also is posible to have a problem whit saftey thermostat. good luck!
Feb 20, 2010 | Cuisinart WM-SW2 Sandwich Maker
Hi Experts, I need to unlock Nokia N95 8GB from Rogers wireless, Imei: 352946021847296, V11.2.011, RM-421, Nokia N95(b1.03) Thank you very much for your help . Wasi
You get the unlocking code from http://www.mobile-unlocker.com/ .It provides the unlocking code & instructions..By using this you can unlock your mobile easily..
Oct 09, 2009 | Cell Phones
After a load it makes a sound and as if the door
your lock could be bad, but when it unlocks it buzzes as if already unlocked? Is the door actully unlocked during the cycle but display reports locked? this would be a bad switch within the lock asm
Jul 14, 2009 | GE Energy Star WCVH6260F Front Load Washer
I forgot my security code and can't access my phone
Good morning. its Wasi Effendi from Karachi Pakistan. and i forgot the Security Code of my LGkg800 mobile. please help me to solve this problem.
Regards, Wasi Effendi
Oct 13, 2008 | LG KG800 Cellular Phone
Lost light Whirlpool Regal refrigerator
two ways might first un plug the unit take the bulb ou and with your finger pull up on the contact inside the light socket ***** the bulb back in and try it if that doesn't work unplug the unit and with a mall screwdriver pry out the switch un plug one wire and with a meter check it to see if its working right or just replace it
Mar 12, 2008 | Refrigerators
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Epson Perfection 4870 PRO Flatbed Scanner Logo
246 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
