Question about IBM ThinkPad T43 Notebook
I have IBM T43 laptop. i want to connect it to a TV. How can i go about it.
Connect S-Video cable and RCAs for sound. Then set input on tv to video. Start LT - logon, etc. Ctrl + Alt + F2. Blam - computer on tv. Ctrl +Atl + F3 to return.
Posted on May 22, 2009
    President:
  • IBM Master
  • 1,314 Answers
You need to get a VGA to <whatever tv input you want> for example a vga to rca component cable, or a VGA to HDMI cable, etc. You can purchase these online.
Posted on Jun 22, 2008
  • Kevin Shafer
    Kevin Shafer Jun 22, 2008
    Oh and then once you get the correct cable, select your tv to display from the correct place and press the key combination on your laptop that will allow it to display on an external display.
  • 130 Answers
SOURCE: ibm think pad t43 /1872/bb6 i want see where is security chip laptop mainboard\
you may find the answer to your question, better at the Lenovo web site, and do a search on the think pad and find your mod. and the select service manual, and download it in the pdf file of adoby, and you find all your answers there on your think pad as they are the manufacturer of all IBM think Pads since the early 2000's
Posted on Jun 15, 2008
  • 148 Answers
SOURCE: ibm t43 laptop's bluetooth cannot find devices
You do have BOTH the laptop and the device in discovery mode, dont you? Some devices have pairing passwords that must be entered in order to connect them. Phones must first have bluetooth turned on, then put in discovery mode. Phones typically ask you to set a password. Some devices such as ear buds have a password hardcoded in the device (usually 0000). Try that next. Finally, try uninstalling the bluetooth device on the laptop, then reinstalling it.
Posted on Mar 02, 2009
SOURCE: IBM T43 Bluetooth not working
Press Fn+F5 then push "Turn On. Now your bluetooth device is turned on, connected and working. :P
Posted on Jun 16, 2009
  • 66 Answers
SOURCE: T43 IBM laptop Supervisor password locked How can
As you may know, IBM ThinkPad uses a smalleeprom (ATMEL 24RF08) to store different OEM issues like serial number,UUID, etc. The supervisor password (SVP) is stored also into thislittle chip. So, anybody should figure that he needs to read the eepromin order to find the password string. The first problem is that 24RF08is not an ordinary eeprom. The second is that the password is writtenin a special scan code.
To read this properly you need a software (and an interface) specially designed for this eeprom.
The software is R24RF08 (eeprom reader) and IBMpass (password decoder).
Posted on Sep 10, 2009
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
Ask for Ibm Thinkpad T43 battery Price&#65311;
go to : Canada battery on-line shop,sell Laptop battery, Digital Camera Battery (DC ...... Welcome to buy ThinkPad T42, replacement laptop battery for IBM ThinkPad ...
https://www.linkme.com.au/groups/public
Jul 20, 2010 | IBM ThinkPad T42 Notebook
I need sound driver for IBM laptop T43
Use the link below to download a driver of your thinkpad T43. Click the file link 1ya210ww.exe.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58599
Feb 07, 2010 | IBM ThinkPad T43 Notebook
Ibm t43 compatible hard drive
with ibm when u change new hard disk you much find ibm hadr disk support for laptop, if another type u much run fix hdd
you go here to download soft to do and search hdd supported
http://www-307.ibm.com/pc/support/site.wss/MIGR-62282.html.
Jan 19, 2010 | IBM ThinkPad T43 Notebook
I reloaded xp on IBM t43 but wireless lan is not working. i downloaded driver but still no good
Is the wireless turned on?
Make sure the antenna wires are connected to the WiFi card.
Nov 16, 2009 | IBM ThinkPad T43 Notebook
Jan 06, 2009 | IBM ThinkPad T43 Notebook
Can't set up wireless connection
On IBM laptops, you have to hold "FN" key and push the function key that has the wieless icon on it.
Sep 27, 2008 | IBM ThinkPad T43 Notebook
Enhanced video/TV missing in Device configuration
After looking at the specs of the think pad T43 i think you need a new laptop. The port you need to transfer video from a computer is called S-video. Your laptop don't have it. Srry.
You could look into some sort of breakout box that you could plug into your VGA out port and from there to a TV. The VGA out port is for adding a stand alone monitor and is not compatible with most TV's.
Jan 25, 2008 | IBM ThinkPad T43 Notebook
Wireless / cable connection
By cable connection, do you mean a LAN cable or a phone cable or something else? Let me know and will see what I can do to help.
R-
Nov 07, 2007 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
787 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
