Question about Samsung ML 2010 Laser Printer
Samsung ML 2010 under mac os X 10.5
I have a printer (samsung ML 2010) connected to a u.s.robotics adsl 4-port router (not wireless).
so, i went to "finder/applications/system preferences/printer&fax" and i tried to add a printer. I entered the printer's ip on address tag and tried to print a page...but i received the following message "Attempting to connect to host 192.168.1.1 for printer. Host '192.168.1.1' is busy; will retry in 20 seconds...".
Then i tried to change the protocol from LPD to IPP but the only thing that changed was the message "Connecting to 192.168.1.1 on port 631.Network host '192.168.1.1' is busy; will retry in 20 seconds..."
The printer works fine with usb connection also works fine under windows XP.
  • WRM321 Oct 26, 2008
    I have same printer with similar problem but using a Belkin wired print server. Printer through print server prints just fine from a Windows 2000 laptop. Printer through print server printed just from from Mac OS10.4 but ever since upgrading the iMAC to OS10.5 I can't get print through the print server. The iMAC will print to the ML-2010 just fine when the Samsung printer is directly connected to the iMAC USB port, bypassing the Belkin print server.
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
Posted on Oct 26, 2008
How can i print from my mac pro to printer samsung 2010
You can enable mDNS in your admin page and connect the mac and printer in same network and then you can setup the printer in mac from settings -> printers.
Jan 10, 2015 | Samsung ML 2010 Laser Printer
Samsung laser printer ML 2010 won't print
Dear
For mac pc you have to download the driver from samsung web site and follow the instruction there.
Aug 18, 2014 | Samsung ML-2010 Laser Printer Monochrome...
SPL 5.07 06-27-2006
I've disconnetected my ML-1630 from Apple Time Capsule router and connected it directly to my computer USB port and it worked again !
Feb 10, 2014 | Samsung ML 2010 Laser Printer
My mono laser printer samsung ml2010 is not working after installing window 7. pl. solve the problem.
Try if you want, manually assign a port to your printer. Please follow this steps.
1 Start>Control Panel>Devices and Printers 2 R Click on the ML 2010 icon
3 Select Printer Properties
4 Select Samsung ML-2010 Series
will see new window open
5 Click on the Ports Tab
6 Assign the right USB port
7 Click OK
Go back to Devices and Printers
8 Again Right Click on the ML 2010 icon and Set it as default printer
Jan 05, 2011 | Office Equipment & Supplies
Cannot print on new Macbook with Leopard Mac OS - need driver
I just upgraded to snow leopard and my previous driver was erased, so I did some digging around and found the right driver (it is not included even in the most recent GutenPrint software).
Look at the Global Samsung website - the US Samsung site does not support MacOS drivers.
http://www.samsung.com/download/FileView.aspx?cttfileid=213919&type=Printer&typecode=15&subtype=Laser+Printer&subtypecode=1501&model=ML-1430&filetype=DR&language=
Your OS should ask to install Rosetta to read the file (Zip), but then the install is quick and easy. The printer driver immediately showed up in the printer>setup>driver menu. Prints without a hitch.
Haven't booted my laptop into 64bit kernel, so I don't know if the driver is 64bit compatible - I expect not. Hope this helps.
May 31, 2009 | Samsung ML 1430 Laser Printer
My ML - 2010 SAMSUNG won't print from my IBM computer
Does the driver work try adding the printer again and pay close attention to which port you have connected the printer through and match it in the add printer in the windows printers and faxers folder in control panel
Jan 10, 2009 | Samsung ML 2010 Laser Printer
Ml-1510-700 install for mac 10.4
Download the file ML-1510 Mac OS 10.2.4 or higher, Mac OS 10.4~10.5 (ver.0.97) from the Samsung Download Center (http://www.samsung.com/download/#)
The file is called "
20040714091617593_SPL2.dmg". Then look for the driver called ML-1510 -700 (N.B. not Samsung ML-...)
Jan 17, 2008 | Samsung ML 1510 Laser Printer
Samsung ML 2010 Laser Printer Logo
928 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
