Question about i-mate Smartflip Smartphone
Phone screen blank
Phone get boot up properly, then shows low memory. then after pressing Ok, Desktop appear. When we press start key blank screen appear.
How I can sove the problem.
Thanks
Sudhir
gaursudhir@hotmail.com
    President:
  • 2,692 Answers
Sound to me like you need a new battery. her is the support page for you product; maybe you can find more information there.
https://www.imate.com/Support_DeviceSupport.aspx
Posted on Jan 03, 2009
Message saying windows did not start properly. recent hardware or software change may have caused
There must be a corrupted software drivers.
For quick solution tried to boot in safemode then perform system restore, if it doesn't work tried to restore the last known good configuration.
How to boot in safemode:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
  4. Once your on the Windows desktop, click on Start>All Programs>Accesories>System Tools then select System restore
  5. Choose the recent date or restore point that your computer is working fine.
How to boot in Last know good configuration:
  3. When the Boot menu appears again, and the words "Last Known Good configuration" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Jul 13, 2011 | HP Pavilion a1620n (882780664494) PC...
My Sony Vaio VGC LA2 shows green lines at startup and after windows processing screen it goes blank. The problem started when it used to hang-up whilst the screen saver came on and the system freezes...
have you tried booting in safe mode?
as the system is booting repeatedly press F8 until a menu appears where you use the aarow keys to select safe mode by pressing enter.
Jan 24, 2011 | Sony Computers & Internet
Acer aspire one model gz5 showed hibernate on screen, low battery. turned off. recharged battery, now there is a dark screen, manual was no help
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Jan 10, 2011 | Acer Aspire One Netbook 8.9" Notebook
My phone memory is always low..
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Oct 05, 2009 | Nokia N73 Cellular Phone
Calc. asks to recover memory, display goes blank, keys beep
The following procedure valid for the HP 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Aug 04, 2009 | HP 48gx Calculator
HP48SX keeps asking to recover memory
Here is the procedure to test the good or bad working order of your calculator. The procedure valid for the HP 48G should work for the HP48GX. If any of the test fails the calculator requires service.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Mar 27, 2009 | HP 48gx Calculator
Smartflip
how to get connected to activesync after booting
Jun 24, 2008 | i-mate Smartflip Smartphone
Hp dx2000 boot problem
Hi Robert,
please try these troubleshooting steps,
Resolving the blank screen Follow the instructions below in order to fix this issue:
  1. Remove any CDs, DVDs or memory cards from the computer.
  2. Disconnect all devices from the computer leaving only the original mouse, monitor and keyboard and power cord connected.
  3. Restart the PC. NOTE: If this resolved the issue, see the Preventing the blank screen section at the end of this document.
  4. Press the F1 key repeatedly during the first startup screen until the entering setup message appears.
  5. Press the F5 key to restore the default settings. Use the arrow keys to select YES and press ENTER .
  6. Press the F10 key to save the changes and exit. Use the arrow keys to select YES and press ENTER . The PC restarts.
  7. When the system restarts select Last Known Configuration from the boot menu. The PC should now startup normally. If the blank screen persists continue with the following steps.
  8. Select Safe Mode from the Windows Advanced Options Menu .
  9. Use Microsoft's System Restore feature to restore your computer to an earlier time and correct the issue.
Jun 23, 2008 | Computers & Internet
Dell desktop
  3. Restart the PC.
  10. If disconnecting devices from the PC resolved the startup issue, re-attach one device and then restart the PC. If this is successful, re-attach the next device and restart the computer again. Repeat this process until you find the device that is preventing the PC from starting properly. Contact its manufacturer for advice on this issue. Please, keep your PC software updated in order to possibly prevent the error from occurring in the future:
    • update Windows.
    • update the BIOS.
    • The software for the devices may need to be updated or reinstalled. Contact their manufacturer for information on the latest updates for your devices.
May 21, 2008 | Computers & Internet
Blank screen
right mouse click on the desktop now show the desktop icons? was this ok?
Sep 18, 2007 | Dell Inspiron 6000 Notebook
i-mate Smartflip Smartphone Logo
77 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
