My intello washer 1300 does not spin. i was getting an oe display after the machine was running for about half the cylce but now it will not spin at any speed.
I called an engineer who checked the machine, not sure what he did but it works now.
He said it needs a part but it's working fine after he left.
Posted on Jul 01, 2008
How do you fix Error Code OE on defy laundromaid electrologic 1300 ? Machine washes, but when it should start to spin, nothing happens - it's just making a noise for a while, no water releases and then...
If draining is not completed in a specified time limit the fault code OE will be displayed.
Check the drain hose is free (not kinked or deformed) and check there is no dirt in the drain filter.
The filter is located behind a cover on the kick-panel at the front of the machine.
May 01, 2014 | Washing Machines
My washing machine, which is a LG Intello Washer WM1485FHD is display a code of OE. Could you please advise
That is actually a DE (drain error). Clean out the filter, located behind the access door on the bottom left side on front of the machine. If there was nothing in the filter, replace the pump motor.
Jan 31, 2011 | LG Washing Machines
My LG washer keeps stopping during spin with the display OE.
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
Oct 21, 2010 | LG WM2101H Front Load Washer
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Apr 01, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
