Question about Kitchen Ranges
Camp chef three burner stove model number tb-90lw. gas leak behind knob that turns on burner.fixed prooblem before,can"t remember what I did.
I suggested you remember what you did, and then tell me because I'm having the same problem.
Posted on Jul 10, 2008
Need all the six burners for this Magic Chef bought in an Army Surplus in the 40s. I don't know the Model because the Name Plate is long gone.
Try this place on EBay . http://www.ebay.com/itm/VINTAGE-STOVE-PARTS-Cast-Iron-Antique-Gas-Range-Top-Burner-Set-30s-40s-/160974704050?pt=Figurines&hash=item257ad70db2
Feb 16, 2013 | Camping, Backpacking & Hiking
We have a Camp Chef SMV18S 18" Smoke Vault and
Tanya - You can order replacement parts directly from Camp Chef 800.650.2433.
Have the Model # and Serial Number of your Smoke Vault handy, when you call.
Hope this helped you. Please let me know. Thanks.
Jun 11, 2011 | Grilling
I connect the propane valve to the stove and it doesn't work, i just bought a new propane and still it doesn't work, my grandfater didn't use it for almos 4 years. what could happened?
Here's an easy solution. Turn the Tank Valve OFF, disconnect the hose from the tank and wait 5 minutes. Reconnect connect the hose to the tank and turn the Tank Valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner farthest from the grill first. Once it lights, turn it to it's highest setting and light the remaining burners the same way. Once all are lit, does the flame height look as it should? Is so, you solved the problem. If not, then you need to replace the grill hose/regulator assembly. You can purchase one from any home center or hardware store that sells gas grills and accessories. Take you old one with you for comparison purposes.
If what I suggested solved the problem, remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you solve the problem.
Apr 09, 2011 | Camp Chef TB-90LWG (NG) Grill
Magic Chef Gas Stove Model CGC2536. 1. On just one of the 5 burners the"Lite" function doesn't work. On all the others you hear clicking, and the gas lights. But on one, no clicking at all....
Try Google your manufacture name model # and the word parts. This will not correct your lighting problem. It sounds like you have a igniter switch problem.
always unplug electricity before attempting to repair on any electrical appliance
Sep 04, 2017 | Magic Chef CGC2536 Gas Cooktop
Hi have a " magic
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Jan 05, 2011 | Magic Chef CGS3760 Gas Kitchen Range
My gas stove is clicking all burners are off
There are switches behind all of the knobs that activate the "sparker" when you turn them. Any one of these will spark all 4 burners. Sounds like you have a bad switch that has stuck in the "on" position. Experience tells me to replace all 4 switches - when one goes, then the others aren't too far behind. Get the part number off the switch and google it. Not too expensive. Until you get them replaced, just unplug the stove and light with a match - remember that the oven will not operate without power cause it has a different igniton system.
Sep 06, 2009 | Magic Chef Kitchen Ranges
Magic Chef Range in camp trailer, pilot light in the oven works however, the burner will not light when turned on. No gas flows. Propane furnace works ok and the propane bottle is full. The surface burners...
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
or
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Jun 14, 2009 | Tappan MGF500PBW Gas Kitchen Range
REAR RIGHT AND LEFT FRONTBURNER WON'T IGNITE
May 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
