Question about Kenwood CD-203 5-Disc CD Changer
Bad line output jacks
I just bought this cd changer and the sound cuts in and out when the red/white output jacks are moved i would like to know if they are soldered and how i would go about replacing it. thanks for any advice you can give.
  • Anonymous May 10, 2009
    I've had the same problem with two different Kenwood CD players. The CD do not play all the way through. Each CD whether new or old will skip and sometimes it will stop playing all together. I am beginning to think the product is no good, since I replaced the CD changer and I now have the same problem
  • 53 Answers
I also agree with this answer. It's not hard to resolder the connections. this is a common problem with output jacks. the solder dries up over time and making it brittle and working its way loose. try resoldering the connections and all should be well.
Posted on Dec 23, 2011
    Sniper:
  • 99 Answers
This is a common problem with output jacks. the solder dries up over time and making it brittle and working its way loose. try resoldering the connections and all should be well.
Posted on Aug 23, 2008
What would make speakers sound bad from a CD Changer?
It could be the cd changer is over driving the amp. IF you don't have the right input and output impedence then it sounds bad because the amp clips the signal.
Aug 02, 2014 | Pioneer Car Audio & Video
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
I want to connect my tv to my stereo for sound but it is not working in aux mode can this be done
Your TV must have a sound output, preferable an RCA type output jacks, these are connected to aux or line inputs of your audio amplifier, in some TV sets, you must deactivate speakers at menu to have audio at these outputs, please check your TV user guide for more details.
Feb 20, 2011 | Emerson MS3100 3-Disc CD Changer
There is know sound output when i play a cd/dvd how can i fix this
That will depend on how you have it wired in....
If you are using composite or SD video, you need to connect separate audio cables (round red and white RCA connectors) between the set and the CD/DVD player.
An HDMI connection carries sound and video and if available, should work (this is dependent on the manufacturer of the player- not all will place CD sound through the HDMI connection)
If you are using regular cable coax connections, make sure the TV is on the same channel as the OUT jack on your CD/DVD player. Again, a CD may not play sound if connected in this manner.
If you are using the component video connections (usually a red, blue, and green RCA jack) you also need to connect the red and white audio cables.
Jan 28, 2011 | LG Televison & Video
CD changer output not working
There is an obscure setting for 'AUX' on/off that is hard to find unless you know what you're doing or looked in the manual. Typical Pioneer for ya.
Apr 19, 2009 | Pioneer DEH-P3600 CD Player
Input for Ipod??
remember those cd kits that came with a tape to insert to the (stero)pioneer fh-p404 and the output jack to the cd player? well instead of plugging into cd player plug it to your ipod....my pioneer fh-p404 has a tape deck and i'm able to hear all of my music without cds or tapes and i found the tape kit without the cd player for 6 bucks at walmart go figure!
Dec 09, 2008 | Pioneer FH-P404
Audio output from my TV
take a red and white audio rca cable and cut off one end of the jacks. on the end you cut, solder a headphone output plug on. can also solder on the lines of a pair of headphones (where you've cut off the 1/8 in jack) directly to the rcv jacks.
Nov 07, 2008 | RCA Personal MP3/CD Player
Surround Sound using the video feature
You will not get 'surround sound' from this set only stereo sound. The Video/Aux jack at the back of the unit is an input terminal. You can connect the audio part of your TV(if it has a Line Out jack), dvd player or video game console to this input to get the sound through the stereo system. Use a male-to-male RCA cable to make the connection, they are color coded (Red and White). Press the "Video/Aux"  button to select the input terminal.
Nov 04, 2007 | Sharp CDBA3100 Remanufactured Mini-System...
Kenwood ks-122 in-dash car stereo/cd changer
make sure none of the speaker+/- wires are contacting each other. if even one of them does, most likely all the sound will cut out to protect the internal amplifier. Other than that, the blue/white remote wire is most likely your problem, if the car has some sort of factory amp thats the wire that tells it to turn on and let sound through. its possible that the outputs of the deck are bad, try checking it with a test speaker or in another car
Aug 12, 2007 | Kenwood KDC-135 CD Player
Kenwood CD-203 5-Disc CD Changer Logo
98 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
