Kelvinator aircon kse26hra why heater is on with green light and red light on for defrost what does it mean cannot find manual
3 Suggested Answers
  • 21 Answers
SOURCE: kelvinator aircon is dripping water from air vent in house
Sounds as if unit is freezing over----typically a response to lack of proper ventilation-----check all filters and access panels to unit and clear or clean as needed-----if unit has a drip pan make sure unit has been positioned properly so as to catch excess......properly ventilating unit should resolve issue though
Posted on Jan 15, 2010
Testimonial: "cheers mate problem solved thanks for your expert advice "
SOURCE: my carrier split type non-inverter aircon always blinking
I got the same problem in Samsung aircon. The unit I purchsed died slowly. After that Samsung replaced it with the one have the same problem. They are swearing that the green light blinking problem as a normal function and refusing to fix. Their user manual says it is a problem. I think the affected consumers should join hands to take legal action against this scam.
Posted on Dec 20, 2011
Our freezer door was left open, the last green light was on and it was iced up inside. I switched off and defrosted. When turning on the red light is flashing. Does this mean it is getting cold again?
Just defrost the unit over night and plug in the next day - should work. In meantime check out your manual for the significance of that red light you alluded to..
Sep 15, 2017 | Refrigerators
What does it mean when the power light (the small round light on the front of the heater that indicates the heater is on) is red instead of green?
was reading a rinnai pdf today about this, green means that the unit has power the red means the burner is operating so it just tells you when the gas is going basically, may not be the same for this rinnai model but is on the energy saver 556 so hopefully that explains your heater for you it should be in the owners manual if you have one as pdf i was reading was manual for another rinnai if you don't have a manual you can try downloading just type heater name and model into your google search with manual mentioned there too should bring up a pdf or a link to manual
Nov 16, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I don't know what the lights mean on my Beko chest freezer. Have just found it defrosted and want to make sure the defrost is off. It is switched on at the mains. What lights should be on? I've lost the...
two reds and green are the auto max freeze on indecators the reds go off one at a time when unit drops to safe temp mode.also means unit needs defrosting manually when too much ice is present.
Feb 03, 2010 | Freezers
When I turn the heater on defrost the windows all fog up. 2002 Ford F350SD (diesel)
Is your aircon working okay? The aircon should kick in to dry the air, with the heater in defrost mode. Hope this helps..
Sep 11, 2009 | 2001 Ford F350 Super Duty SuperCab
Owners manual lost
I have some similar swimming pool lights that are rechargeable. If my light, green means that the battery is ready for use, orange means that the battery is getting low, and red means that you need to recharge. I would assume that this is the same for yours (because mine is very similar). Hope this helps.
Jul 12, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Kelvinator novelties chest freezer
check the defrost timer, defrost limit, and defrost heater.
Apr 21, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Defrost light stays on
Try advancing the defrost timer manually.
Jan 16, 2008 | Freezers
What are the lights?
I cannot find any manual or information on the 3 lights. I would assume that the green light means everything is OK, the red means current problem, and the amber means manual defrost is due. Sorry, this is the best I can do. Later.
Aug 24, 2006 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
