Question about Intel DG31PR Motherboard
Audio device is not working
Recently I tried DG31PR motherboard with a dual core processor. Everything is working properly except the audio. The built in graphics card also the built in network card is working fine. I am understanding what's the wrong with the audio device? I installed the driver for audio device still it says no audio device.
What should I do?
Thanks.
  • 21 more comments
  • MISTERBEARS Jun 22, 2008
    HAVING PROBLEM WITH MY DIMESION3100 RUNNING WINDOWS XP NO AUDIO SAY NO SOUND DEVICE INSTALLED OR BAD SOUND DEVICE .WHAT DO I NEED TO DO TO FIX THIS BUY ONE HOW MUCH DO SOUND CARD SOUND DEVICE COST????????????????
  • Anonymous Jun 24, 2008
    I intaled a lot of diferrents drivers and my sond dosen't work´s. I don't no what to do more : Intel DG31PR Motherboard and E4600 dual core
  • SFARI Jun 27, 2008
    mine is a compaq lappi (vista)...i unknowingly deleted my audio device..
    what to do now...plz help.
  • nagarajnaaan Jun 28, 2008
    i have installed xp professional but no sound ,finished installing the drivers but no yellow mark in the device manager -sound devices but its showing no audio devices found , ihave tried many times mother board -DG31PR DUAL CORE PROCESSOR PLS GIVE ME A SOLID
    SOLUTION
  • sunil27482 Jul 04, 2008
    I purchased Intel DG31PR motherboard with a dual 2 core processor, couldnt install audio drivers. The installation failed.
    I have installed xp professional .yellow mark in the device manager -sound I have tried many times mother board -DG31PR Dual 2 Core Processor. pls. give me sold
  • Anonymous Jul 19, 2008
    audio drivers not working inteldg31PR
  • AllenLV Jul 25, 2008
    just "No audio device", no sound...plaes help
  • dhev Aug 07, 2008
    when audio is played it says no audio device
  • malakar_alok Aug 09, 2008
    same problem here
  • nitinkumar01 Aug 10, 2008
    i have purchased intel dual core with DG31PR motherboard ,audio device is not working .driver couldn't get installed from cd which came with the motherboaard. I tried installing it from the driver software from the intel website but again some problem is coming and driver is not getting installed...please help me out
  • Anonymous Sep 09, 2008
    jhgj
  • Anonymous Oct 30, 2008
    when audio is played it say no audio device
  • manjith8124 Nov 01, 2008
    everything is workin properly but i cant install audio drive software and my motherboard supports realtek high definition buss audio....
    please kindly assist me on this
    thank you.
  • suresh_stg Nov 14, 2008
    I've DG31PR intel motherboard,when i'm install audio driver then it shows succesfully installed but there when we execute movie maker than it shows no mixer installed and if we check sound and audio devices from Control panel than the dialog box shows no devices installed and there is no sound control in system
  • CountVak Nov 26, 2008
    My sound worked for about one day last February and I have not had sound since. I have the Intel DG31PR board. I have installed the Realtek HDA so many times I'm sick of it and have even contacted Realtek. They had me do some test and send them the information and said it was not them. I upgraded to Vista Ultimate a couple months ago as I was told it would solve the issue but here I am! I have recently downloaded a free program called The Ultimate Troubleshooter. This program says it can fix the problem, like they all do, if I pay them money. What is the deal with this board and how do you get sound. I have the Intel DG31PR board, 2 megs memory, Windows Vista Ultimate. The device manager shows everything as working fine. What do I do? Please help!
  • Anonymous Nov 30, 2008
    sir;
    i m using intel dg 31 but sir when i instell audio driver then
  • swetank Dec 22, 2008
    audio drivers install failure
  • Anonymous Dec 26, 2008
    audio device is not working and even coud'nt installed
  • imsiri07 Jan 03, 2009
    audio drivers installing failed
  • shan4djfun Jan 04, 2009
    I have the same problem with Intel GD31PR.Dual Core 2.2 proccessor and No sound it fails to install.....plz help
  • dsouzaranjan Feb 06, 2009
    Hello
    Even I have DG31PR motherboard with a dual core processor & XP profesional and got the same problem. As per the above detials I downloaded the driver with the help of below link.
    http://www.intel.com/support/motherboard...
    But I cannot install the same. While installing eror is showing like Eror code 0XE0000227.
    Kindly try to solve my problem.
    Thanking you.
  • Anonymous Apr 16, 2009
    audio not working
  • abhi302 May 12, 2009
    i have  DG31PR mother board i installed drivers but there is no sound in one spesker, speakers is alright (creative 2.1) what can i do
I have been working on this for months and finally got everything including front audio panel going. First Download the latest realtek audio drivers available  from intel's website or go here and download #3 http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows%2A+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21. Next goto control panel and add/remove programs then look for realtek audio drivers that have been previously installed. Remove program if one is found. Then go to device manager (right click my computer, go to properties, Then hardware, then device manager. Click on the"+" in front of system devices. Find "microsoft uaa bus driver for high defintion audio". Right click that and select, "disable". Then right click it again and "unintstall" the device. This will allow you to install the audio drivers on your disc, or ones you have downloaded to install without an error message. Once done install your audio drivers and restart your PC and windows should start dectecting your new hardware. An installation wizzard pops up. Install the files needed yourself from a specific location, not a disk. It will ask for location of file name "hdaudbus.sys". That file is in C:/Windows/System32 folder. If it's not there, which it should be, just find and download that one file but it should already be there. I have done all this on xp home ed, sp3. I now have sound, and my front audio panel works. Please let me know if you have any problems by emailing me at chadmon10@hotmail.com
Posted on Feb 16, 2009
Posted on Jul 04, 2008
Its easy i figured it out guyz. The same problem with every Intel new MB's. Basically what you have to do is stop trying to install it. Then follow below steps to setup it correctly.
1. Unstall any setup regarding audio device from add remove programs
Eg: high definition audio driver,ect
2. Then goto StartMenu>click run and type msconfig ---> press enter
3. Goto start up tab and desable all the startups presently available (important all the start up's should be removed)
4. Press apply and agree to restart
5. After restarting again try to install (it works this time "have patience")
6. It will Automatically restart again AND THAT's IT
IT REALLY WORKS AND MOST IMPORTANLY UNSTALLING ANY PRVIOUS DRIVER'S REGARDING SOUND CARD IS CRITICAL>
Posted on Mar 29, 2009
Whenever i try to install the audio ... but its not work
Posted on Mar 28, 2009
  • 90 Answers
Hi buddy!
first check the audio card if you really install.heres a few step.
1. right click the My Computer,Properties
2.Hardware,Device Manager
and if theres is a color yellow means not install.
And Click Start,Run
Type <dxdiag> and enter here you can test the sound also the graphics.
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Jun 22, 2008
Audio Drivers Fail to Install
When installing Sigmatel* or Realtek* audio drivers (either from the Express Installer CD or using the latest driver download available from the web), the installation may fail with either of the following error messages:
  • Device Object not present, restart the system and run setup again.
  • The system does not support the driver you are attempting to install.
The Universal Audio Architecture (UAA) High Definition Audio class driver for Windows* may be corrupted or causing problems with the audio driver installation.
Try this first:
  1. Click Start > Control Panel > Add/Remove Programs.
  2. Look for the following two items: Realtek* High Definition Audio Driver and High Definition Audio driver Package - KB888111.
  3. If these items are listed in Add/Remove programs, remove them.
  4. Restart Windows.
  5. Download the latest audio driver for your desktop board from Download Center.
  6. Double-click the filename to extract the files.
  7. Go to the folder where the files have been extracted and browse to the \HDAQFE\xpsp2\us\ folder or the \MSHDQFE\Win2K_XP\us\ folder. (The name of this folder depends on your desktop board model.)
  8. Double-click the file kb888111xpsp2.exe to install the High Definition Audio Driver Package.
  9. Restart Windows.
  10. Install the audio driver.
If the above steps do not resolve the problem, try reinstalling Windows as follows:
  1. Disable audio in BIOS before the installing Windows:
    • During boot, enter the BIOS setup by pressing F2.
    • Disable audio on the Advanced > Peripheral Configuration menu.
    • Press F10 to Save and Exit.
  2. Install Windows.
  3. Install the latest Service Pack for your version of Windows.
  4. Install the Intel® Chipset Software Installation Utility (INF Utility).
  5. Install all of rest of the latest drivers for your board, EXCEPT the audio driver.
  6. Re-enable audio in BIOS:
    • Enable audio on the Advanced > Peripheral Configuration menu.
  7. Restart the system and cancel any “new hardware found” messages.
  8. Install the latest audio driver.
  9. Restart the system.
THESE STEPS SOLVED MY PROBLEM!
PL. VISIT THE PAGE
http://www.intel.com/support/motherboards/desktop/sb/CS-020642.htm#driversfail
Posted on Feb 06, 2009
THIS IS BECAUSE OF SOME CONFLICT WITH THE MICROSofT UAA BUS DRIVERS FOR HD AUDIO..
UNINSTALL THIS FROM DEVICE MANAGER ---SYSTEM
AND THEN INSTALL UR AUDIO DRIVERS.. VOILA DONE..
this is the solution ...
Posted on Dec 26, 2008
I installed sound card driver but "failiure" message is shown so what want i do?
Posted on Apr 11, 2009
now my audio device cannot hear.......i dont y it happen....but something like chating..ok...but i cannot hear wen i play videos or audios..?waiting for ur reply...pls giv solution....
Posted on Feb 04, 2009
I install vga 1g geforce in intel dg31pr once work and once work proplems in colour but in vga build in good. what is the proplem please
Please check whether you had run the patch for XPSP2 which is available only in drivers CD. First you should run this patch then you have to install Audio drivers, definitely it will work. (Also try by reformatting and go through this procedure.)
Note: Make sure you have run the correct patch and correct audio drivers.
Well, finally update me with rating and with some comments.
Pavan Kumar H S
Wrigley india,
Rajankunte post
Doddaballapura Road
Bangalore - 560064.
Posted on Dec 16, 2008
Hi there
here is the solution for u
in run type msconfig and go to the tab startup
unchek all and restart the system
now install your audio drivers (it works )
again type msconfig and go to startup and chk all
now restart the system and enjoy the music...........
Posted on Sep 23, 2008
Khjk
Posted on Sep 14, 2008
The fix is the following:
Go the intel website and download the latest HD audio driver for your mobo. Install it and all should be fine.
Its a bit of a strange problem which I had on a pearl creek board, but its sorted now.
CyberStorm_ZA
Posted on Aug 31, 2008
Error is cumin no sound card is installed .... wat to do ..?
Posted on Aug 28, 2008
Install windows vista....... work fine
Posted on Jul 19, 2008
You should try flashing the BIOS with the latest version from Intel's website. It's not listed as a fix for sound, but the flash let my XP system recognize there was a sound card.
http://downloadcenter.intel.com/Filter_Results.aspx?strTypes=all&ProductID=2839&OSFullName=OS+Independent&lang=eng&strOSs=38&submit=Go%21
Posted on Jun 26, 2008
  • 22 Answers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
126
Posted on Mar 13, 2009
2 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: problem in audio driver for dg31pr
Visit this link: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839, select your OS and download the latest sound driver. Also run your add hardware from control panel even if you have to select the device manually.........sodeep
Posted on Jun 12, 2009
Error E 0000227
It's an audio error. Download the audio drivers, AND install them.
Need guidance?
Is the motherboard in an operational computer, that is connected to the internet?
Try the automated driver detection, and update the drivers.
http://www.intel.com/p/en_US/support/highlights/dsktpboards/dg31pr
See where it states - Intel Desktop Board DG31PR, and Latest Downloads underneath it?
Left-click on the blue -
Automatically detect and update drivers and software
Motherboard is not in an operational computer that is connected to the internet. Then you will have to download the Realtek audio drivers, burn them to a disk, and install them on that motherboard.
(Operating in a computer)
For guidance on how to perform this, state in a Comment.
For additional questions state in a Comment.
Regards,
joecoolvette
May 20, 2012 | Intel DG31PR Motherboard w Pentium Dual...
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
Jul 08, 2011 | Intel DG31PR Motherboard
Audio driver problem. I have no audio drivers for this board.
download here, i hope this helpfull, please rate helpfull or very helpfull if you think this helpfull
thanks for using fixya
Jan 20, 2011 | Intel DG31PR Motherboard w Pentium Dual...
After installing audio driver it is not shown in computer except add/remove programs
see in device manager,there was something missing.uninstall audio driver from there and then restart your system.after restart again you will go to device manager and from there you have to manually install audio driver...
Apr 27, 2010 | Intel DG31PR Motherboard
Realtek Audio driver Installation failure on DG PR31
First uninstall driver and software from add remove program. Then install chipset driver>>then run sound driver setup>>when it will ask for driver search click cancel after the installation process restart computer.
Sep 20, 2009 | Intel DG31PR Motherboard
Hello , i have made update to my DG31PR bios , the new update version is 0066 ,,, after update the pc cant enter the windows and i have intel Pentium 4 processor 3.00GHz / 2m ,, after that i return the...
you have no need to update or upgrade your bios version anywhere if it work properly, but now if u have prob wid it,
1. try any other processor (P4, Dual Core, Core 2 Duo e.t.c)
2. reinstall any other version (0066 or 0052), just change the way of installation (this time install it from Floppy drive or other one, which is different to the 1st time u install from)
Jun 13, 2009 | Intel DG31PR Motherboard
Problem in audio driver for dg31pr
Jun 12, 2009 | Intel DG31PR Motherboard
Audio driver
Hello here is a link to download the drivers for your motherboard
I searched Google using the error code you provided and found this problem to be very common. The most common solution was this: [quote] open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio" uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.) install realtek driver the realtek driver includes the UAA driver too. Good luck
Mar 07, 2009 | Intel DG31PR Motherboard
Installation failed
Hi sunil27482, please create a folder on you're desktop & name it sound. Go to this Intel link & download driver number 3 into the sound folder.
Audio: Intel® HD Audio Controller - Realtek* Codec 4/29/2008
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Once downloaded into the sound folder uncompress the driver software by double left clicking on the .exe file. You will now see a new folder named "AUD_allOS_5605_PV_Realtek".
Now go back into device manager &
Right click once on the yellow ! point & left click once on update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find you're desktop & open the sound folder you created. Click once on the AUD_allOS_5605_PV_Realtek folder so it is high lighted. Than click OK. Windows will find the correct driver software & install it.
If you have any trouble, please list here the issue.
Good Luck!
Mike
Jul 04, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
3,259 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
