Question about Whirlpool Dryers
How to remove dryer drum from 15 yr old kenmore electric dryer to replace dryer belt, idler pulley, and support rollers.
  • 525 Answers
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0100_15.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 22, 2008
10 yr old Amana electric dryer. Will not turn on only buzzes and smells hot when you push the button, drum will not rotate clockwise
Hi
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley, or a something jamming the rollers you cannot see.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Please take time to rate me
Bud
Oct 01, 2012 | Amana Dryers
Drum will not tumble. No heat.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Dec 04, 2010 | Kenmore 62602 Electric Dryer
The power of the dryer is on, but it is not engaging. It is an electric dryer, older model about 13 years old.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Note: Some of the tops tilt backwards and do not have to be removed completly.
This is a FREE answer, Please rate me
Oct 10, 2010 | Kenmore Dryers
1 yr old whirlpool dryer, belt and pulley ok but will drum will not turn. motor appears to be ok
Oct 05, 2010 | Dryers
My Kenmore dryer is around 10 years old. Will not start after finishing up a load. When you push the start button I can just hear a clicking noise. Any advise?
Sep 30, 2010 | Kenmore 63942 Dryer
23 year old dryer, model # 86673700, drum won't turn. will heat up and motor wil run. how do i get in to check the belt?
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections. Remove the lint filter screws and filter.
Good luck,
I hope this helps
Please rate me
Thank you
Aug 14, 2010 | Kenmore Dryers
Dryer sounds like its slipping when it first starts It is a kenmore elite dryer model number 41783052201
Sounds like your problem may be a worn belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace your drum belt and if you have a front loading machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 13, 2009 | Kenmore 62602 Electric Dryer
My kenmore HD60 series dryer drum does not turn.
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have a front loading machine.
Good luck,
I hope this helps
Nov 09, 2009 | Kenmore 62602 Electric Dryer
My kenmore model 80 dryer drum will not spin
Good luck,
I hope this helps
Nov 03, 2009 | Kenmore 62602 Electric Dryer
Kenmore elite sqeels then stops, timer keeps moving
Good luck,
I hope this helps
Nov 01, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
81 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
