Question about Smeg 18 in. DWD409SS Built-in Dishwasher
Dishwasher Smeg DWD409SS
We have an E1 error code on our dishwasher. Anti flood system tripped. Can we re-set this and if so please can you tell us how. The model is Smeg DWD409SS.
  • Anonymous Mar 12, 2014
    E1 message, on dishwasher, after flooding when both sinks were full. Can not clear error message and turn off power on dishwasher
Hi
Please go to www.smeg-service.co.uk/support
Posted on Aug 21, 2008
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
Smeg D1 612 CA dishwasher wont run
You may have to give a little more information.
Have a look at the manual, here -
http://www.manualslib.com/manual/343502/Smeg-Di612ca.html
and check for error codes/lights etc (p17; faults E1-E9)
Hope this helps
Oct 28, 2013 | Smeg Dishwashers
WE HAVE A SMEG DISHWASHER AND IT KEEPS COMING UP ERROR 1 MESSAGE ANTI FLOODING SYSTEM HAS BEEN TRIPPED HOW DO WE FIX
there is a water leak in your dishwasher. Need to find the source of the leak. Usually a cracked hose or water leak through door gasket.
You can check this by turning off the water supply and mains power. Take dishwasher out from under bench if you can and tilt it back and forth a few times. Wait 10 minutes and turn back the power. Check if flood message has disappeared.
Dec 10, 2012 | Smeg Dishwashers
Error code 1
Contact a qualified appliance technician if you see an E1 error. An E1 error appears when the anti-flooding system has been activated
God bless you.
Sep 27, 2012 | Smeg Dishwashers
E1 error code indicating anti flood has been tripped,it doesn't sound like it's taking on water. All the filters are clear. This unit has cost me a fortune in repairs since the warranty ran out,it wasn't...
Hello there:
Yes this is a common error code on these machines the anti flood switch that is a sensor that sits at the bottom of the machine when water builds up on this switch this error code will illuminate
So what you need to do is disconnect any power to the machine
then if your has a panel at the bottom that can be removed remove it and look to see if there is a little tray in there if so it needs to be emptied this is normally done by tipping the machine towards you at a 45 deg angle then hold it there for 45 seconds this allows for the flood switch to be reset
Now take a towel and dry up any wires that are wet you may be able to see the sensor too where the tray is if so make sure this is totaly dry
then restore power to the machine and give it a try i have had to use a hair dryer sometimes also to help dry the wires under these machines ok that is just a hint though ok?
Hope this solution has helped you out Please feel free to rate this solution for me it helps get the best posiable solutions for customers ok?
Best regards Mike
Jan 17, 2011 | Smeg DWI614 Built-in Dishwasher
I have a Smeg DWF410 dishwasher with error message E9
E9 is a repetative E1 error - flood protection activated. Check tray under machine for leaks. If dry, find youself a nice long cable tie and lift the rubber flap at the back of the sump moulding underr the filters. Proceed as if rodding out the drains - you'll be surprised how much muck and goo comes out. Usually solves it.
If problem still persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 13, 2009 | Smeg 18 in. DWF410SS Slim-Line...
Smeg 18 in. DWD409SS Built-in Dishwasher Logo
2,231 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
