Question about Compaq Presario Notebook
Laptop overheating hi please will you advise, my laptop keeps over heating and turns itself off.
    Problem Solver:
  • 7 Answers
Had a similar problem. Whenever I played then it would after just freeze and shutdown. Was also getting really hot. The solution was real simple:
At the rear left corner of my 7720 is the heat exhaust vent. Right next to it is the power supply socket. The end of the power cable (jack end) had a large plastic casing around it, larger than a AA battery. Because of how the laptop was set up on my desk this casing around the cable lay right against the exhaust vent and stopped the hot air from escaping. All I did was turn the power cable so it faced right instead of left and, hey presto, all was sorted.
Posted on Jan 16, 2009
    Problem Solver:
  • 5 Answers
Hello
I understand that your notebook heating up and restarts automatically.
The issue might be with the Fan of your notebook or Hard Drive .
To isolate the issue please perform hard drive self test. This will display whether your notebook hard drive is good or have gone bad. If the hard drive self test result is bad/fail. Then, I am afraid that you need to replace hard drive of your notebook.
To perform Hard Drive self test, here are the steps.
1. Restart the notebook.
2. Tap the F10 key as soon as the HP logo appears.
3. Using the arrow keys, navigate to Dignostics Menu and start the Hard Drive self test.
4. Once finished, navigate to Exit Menu, select "Exit Discarding Changes".
If you are using XP operating system in your notebook. Then in the 3rd steps navigate to Tools instead of Diagnostics.
If you find the above information is useful then please rate me.
Posted on Jun 22, 2008
It is been 1 year that I bought my laptop.I have Toshiba A665-s6065.when I use it for some hours in normal cases(internet,movie,...),Toshiba health monitor shows me that my CPU temperature is going up and...
Hi RGH.
1. Fix Internal Cooling. The first and most important thing you need to do when your laptop is overheatingis to clean the fan(s) that provide(s) cooling to the CPU and graphics card. Over time, they build up layers of dust and dirt that slow them down and block airflow.
How to Fix an Overheating Laptop - MakeUseOf.
What can happen to a laptop if it overheats?
A laptop that severely overheats causes damage to the internal components. Before this happens, the laptop should attempt to shut itself down. ... If you smell smoke, a burning odor, the fans never run or the fan runs all the time, be careful to avoid ruining your laptop.
Negative Effects of an Overheated Laptop ' Chron.com.
How can I stop my laptop from overheating while playing games?
Maintain a cool environment.Try keeping your laptop in an air-conditioned or cool area to allow your system to cool down and prevent it from overheating. Consider using a heat sink. Use a steel flat bar as an external heat sink. It works because your computer has to heat up more mass before it overheats.
3 Ways to Keep Your Laptop from Overheating - wikiHow
HOPE THIS HELPS YOU OUT.
Nov 04, 2017 | Toshiba Satellite A665S6065 Notebook
My toshiba windows vista ultimate gets over heated an d shut down itself foe every 5 minutes what to do
Please check the internal exhaust fan for malfunction. For temporarily you can use external exhaust fan to prevent it from overheating while use the laptop.
Regards
Jan 20, 2011 | Toshiba Computers & Internet
Hp 6735s turnin of itself and is overheating
To avoid laptop overheating, follow the information from this link.
Oct 26, 2010 | HP Compaq 6735s Notebook
Shut down itself
Hi i'm Rain.
If your Laptop is over heating you may need to look into a stronger type of cooling system { Fan }
But for now lets set up your power Options settings
to try to keep your CPU cool.
In power options select Power Saver.
If you see the selection to keep the fan running select it also. save and exit.
Hopefully this will help to keep your system cool until you can service it.
Nov 25, 2009 | Compaq Presario Notebook
The labtop becoms heated and suddenly turn off
Hi
Sounds like the fan is either blocked or not functioning correctly. Advise you take to a good computer shop before further damage is done.
Taz
Nov 09, 2009 | Toshiba Satellite Pro L300 Notebook
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
Freezes up and turns itself off
its is related to heat why don't u contact youw service centre...while using laptops give them a space for air to flow and use them in low dust area
May 20, 2009 | Compaq Presario 700 470024-192 Notebook
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? My HP laptop keeps shutting itself off after...
hi,
Please check for the exhaust,is it coming properly and check the bottom of the Notebook is it heating ?
If heating then this is the issue with the processor fan.
If the temprature is normal then check in BIOS(leave the system in BIOS mode for 8 minutes) if then also it is turning off surely this is the heating issue.
If above mentioned is not working please revert.
Feb 09, 2009 | HP Computers & Internet
Overheated laptop for advent 7211
hi buy a can of air take cover off and give it a good blow, also try a laptop fan tray.
makesure there is nothing near it when its on and there is a good space from bottom
Dec 04, 2008 | Computers & Internet
Compaq Presario Notebook Logo
216 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
