It will definately work in the wall,,,, all you need to make sure about the correct size if you can buy one because it will need the gaps to be filled so its gona be better if you can get a correct wall sized AC windows type.
Air Bocahttps://www.airboca.com > what-to-do-if-your-ac-has-...
Nov 14, 2022 - Additionally, a common cause of blown fuses (and trips to the AC ... on the fuse, you can inspect the access panel of your air conditioner.
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.7 · 285 votes
Missing: Fedders A6Q10F2A
Stack Exchangehttps://diy.stackexchange.com > questions > why-does...
Sep 7, 2013 - Which fuse is blowing? There are 4 common locations for fuses: main fuse panel for air handler, main fuse panel for condenser, local disconnect ... 6 answers · 1 vote: Long-term darkening of a fuse on a high-draw circuit like an AC is not unusual. How
Tip it outward so the concensate will tend to overflow outside. Be careful you dont drop it.
Typically, window AC will collect the water in a tray to help cool the bottom ocondenser and rely oin evaporation to get rid of the water. Sometimes, during high humidity, it doesn't evaporate quickly enough and will spill out of the pan.
You could drill a hole in the pan outside ... whicl will drain the water ... but reduce the efficciency.
Interesting - I just got your request for a chat ... here is your answer ... and you didnt have to pay for it.
I think you probably could. As most manufacturers of portable AC units allow for this. It's what called a semi -permanent installation . The dryer duct idea will work if the shaft part of the dryer duct is the same diameter as the window mount duct and the shaft of the dryer duct is long enough to go thru the wall and leave enough for the AC Exhaust Duct to hook to. Be sure that the flap door of the dryer duct moves freely and will not get stuck in the closed position. That could be a big problem if it does. Keep in mind, you will not be able to add any length the AC duct hose. It must remain the same.
Hope this helped answer your question and things for choosing FixYa.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when: 1. the question is unclear, incomplete, or poorly worded... 2. the question is mis-categorized - so the correct experts aren't viewing it... 3. the question requires an answer for something that cannot be explained online adequately... 4. specific training, tools, or equipment are required to avoid injury or death... 5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason. Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are... $ 9.99 answer for one question. $12.99 Live Real-Time online chat or premium e-mail support. $29.99 Live Real Time phone support Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership. Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I would contact your local LG. Also many electronic places sell universal ac remotes (check the packaging to ensure that it can control LG's). The universals are cheaper and easy to set up (they come with step-by-step setup instructions).
Hope this helps
I take the time to answer your question so please rate me
If the Ac unit can not fit your window, you can put a wall unit, you don’t have to open the wall and mount a stable unit, you just need to buy a portable AC unit put on.
