Question about Whirlpool Dishwashers
Hi my dishwasher generation 2000 will not work every time i connect the power it trips all the downstairs sockets
  • 76 Answers
Take it in for a service it may need a new fuse or something simple but what ever you do dont plug it in again they can start fires very quickly wait until a professional comes and has a look at it
Posted on Jun 22, 2008
Indesit is70c
its a saftey device, called a "thermodisk". It's purpose is to turn off the heating coil or stop gas flow in the event of over heating. If the thermodisk is bad, trying to over ride it (trying to get it to run) will trip the breaker. Its about 10 bucks and easy to replace.
Dec 31, 2013 | Dryers
I just installed my diswasher and im not getting power to the unit. It was given to me by a friend and worked fine for her. All of my connections are good and the breaker is not tripped
Are the power connections to the unit 'hard-wired' or a plug and socket connection? If a socket, try a lamp in the socket to make sure that power is present. Otherwise, the power connection junction box at the machine should be checked with a voltmeter for 115 volts AC. If ok, then there is a problem within the machine. At this point, you may need to enlist someone that can troubleshoot the wiring and switches inside. Hope this helps!
Oct 10, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Hotpoint wm53 unknown problem
Hi.
Unplug the motor and try it again, if it does not trip, then the prob is the motor, could be worn carbons.
Re the noise, remove belt, and spin drum round by hand, if it is noisy and rumbling, then main bearings have failed, quite a big job to put right.
Please rate my comments.
Thanks.
Jun 17, 2009 | Hotpoint Washing Machines
Dishwasher tripping all sockets
Your unit has a short in it...could be anywhere. You really need to use a VOM to troubleshoot the problem
Apr 29, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Bush btv180t- connections
Hi ,
Thanx for the reply.
managed to sort it second time around.
Just ran the coax from the rf socket downstairs to the back of the tv link ,which is attatched into the ariel socket in the back of upstairs tv.
the tv link comes with good instructions,but need reading carefully first.
Jan 14, 2009 | Televison & Video
Fisher & paykel trips the electric sockets
does it trip power as soon as its plugged in.drain hose may have gotten kinked behind drawer and broke leaking on to power board behind lower drawer. THE POWER to this thing must be removed before taking anything apart on these dishwashers. IT IS RECCOMENDED TO HAVE A TRAINED TECH WORK ON THIS they are delicate good luck!
Dec 29, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dryer tripped out during cycle and knocked off all downstairs sockets. Have had element tested and found no fault. Tech suggested plug dryer in without the element to see if trips (to eliminate element)...
An electric dryer must be on a circuit by itself. If you lost power to downstairs sockets, you will need an electrician to separate the 120volt side from the 240volt side. You may not have a problem at all with the dryer. If another appliance was operating at the same time as your dryer, that appliance would have overloaded your circuit and tripped the breaker. Please have this looked into by an electrician to avert a possible fire!
Your tech should have recognized this situation or maybe I have misunderstood the issue, but I gave my opinion based on the question above,
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 07, 2008 | Whirlpool Dryers
Dishwasher keeps throwing circuit breaker halfway thru cylce
Most likely cause is a minor leak shorting acroos the wires, check in base for water stains. Regards Advisor
Aug 31, 2007 | Maytag 24 in. MD5600 Jetclean II Built-in...
Dishwashers Logo
60 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
