Putting a window air conditioner in the wall
My in the wall air conditioner died, and I'd like to replace it, however due to budget constraints would much rather get a cheaper window air conditioner than a much more expensive "through the wall" air conditioner. I've seen an LG 10,000 and 11,500 model that are in my price range, but I'm wondering... will these work in the wall? it's impossible for me to mount in my window.
The dimensions of the current hole (sleeve I guess) is 16X27, and the size of the air conditioners are 15X23 and 16X27 (min). Will either of these work properly in the wall?
    Champion:
  • 254 Answers
I dont see a problem with these working in the wall, however you will probably need to install a condensate line to drain away the water that will be left from condensation. These items may be purchased from any hardware store.
Hope this helps Ya please rate me
Posted on Jun 22, 2008
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Can the styrofoam insulation in our air conditioner be replaced or patched?
Yes it can but you will have to use expandable foam. You must shape it after it drys. Old trick, works like a charm. Should be an under $5 repair
May 29, 2012 | Whirlpool ACQ158XP Wall/Window Air...
My air conditioner is making a loud noise when I turn it on...even when it is on fan mode. HELP Please!
ir could be the plastic front vibrating, try putting your hand on it and see if you can stop it
May 18, 2011 | Friedrich CP06C10 Wall/Window Air...
Replacement of window unit
Yes,you can,they are basically the same,you can get a 18000 btu to go in it.The more the btu`s,the higher they are anyhow.
Jul 22, 2010 | Heating & Cooling
Hi there, few days ago my HAIER 12,000 btu, ESA3125 died. it smell like burning wires. after i disconnect it from the wall and after putting my rubber gloves i open the case that holds the circuit and...
You should be able to take the information you have (on the capacitor) to Air Conditioning Supply House and purchase an exact replacement.
As to the diagram. There should be a schematic on the unit - somewhere. Usually located on an 'inside' panel.
Unless someone has removed it - the AC will have a schematic on it.
May 05, 2010 | Haier ESA3125 Wall/Window Air Conditioner
I am turning on my window air conditioner for the first time since last summer. Air is blowing but water is coming out of the vents as if water is inside.
get your AC serviced, due to dust and all the coils are choked this is the reason for water is comming out from the evtns
Mar 19, 2010 | Frigidaire FAC124 wall/Window Air...
My GE A/C window unit won't shut off or let me change the temp.
Please get the thermostat replaced before your compressor breaks down due to continuous running..............sodeep
Jun 18, 2009 | GE Deluxe AGM08LJ Thru-Wall/Window Air...
Fridgedaire; freezing up
If the coils freezes up half-way-down and lower is due to low freon psi.
Aug 21, 2008 | Frigidaire FAC126P1 wall/window Air...
Thru wall/ Window ac units
Try this ttech http://www.amazon.com/Using-MultiSIM-Troubleshooting-DC-AC/dp/1401852548
Aug 01, 2007 | Whirlpool ACQ158XP Wall/Window Air...
Heating & Cooling Logo
320 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
