Question about Hoover UltraCare HC6 150M Front Load Washer
Hoover ultracare hc6 150m. Changed drum bearings today .but pulled of spade terminals to power switch .Established live and nuetral feed to switch ,but unable to establish switching pair polarity..Wires going to= door lock, pressure sw,and power lamp .but cannot be sure if using nuetral switching on pressure switch ect
  • Hoover Master
  • 732 Answers
Now THIS is strange! I hunted HOOVER and got this:
"Your search for "hoover ultracare hc6" resulted in no products."
and
"Your search for "hoover ultracare hc6 150m" resulted in no products."?
Even a GOOGLE SEARCH had no real hits for:
hoover ultracare hc6 replacement parts
...had ZERO results... well actually there were some hits but no actual "part sellers" and the DO want to make money!
Posted on Dec 25, 2017
4 Suggested Answers
garing
  • 998 Answers
SOURCE: Hoover Washing machine wont spin
look at the belt and thumbs up
Posted on Aug 09, 2009
  • 4 Answers
SOURCE: hoover SE230 i,ve misplaced my drawing of the door
Green cable to number 1
white cable with silver spade fitting to number 3
double white cable to number 2
Posted on Nov 09, 2009
SOURCE: My hoover washing machine top
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
Posted on Oct 10, 2011
Where is the filter located on a hoover 1100 ultracare washing machine?
usually you remove the drum then you can see it. but dont take my word for it.
Sep 21, 2017 | Hoover Washing Machines
I have a Hoover washing machine HNL662 front loader and am getting an electric shock from the drum.
Silly question time first ;-0)
Has this only just started or only just noticed- what's changed, please? Have you previously always worn slippers/shoes which would have isolated you from 'earth' but are not now- because of a change of floor covering for instance?
Possible causes;-
1) the socket into which the washer plugs has no earth continuity, or has lost it,
2) the plug has recently been rewired without a good earth
3) the 'earthing' cable inside the washer has come off. I doubt the latter as it would normally be bolted on to the chassis, or sometimes with a spade terminal.
If you have no-one handy and 'electrically' competent to check, call a local electrician to do the initial checking. It's an easy enough task!
Good luck,
John C
Feb 27, 2011 | Hoover Washing Machines
Dimplex XT24 Series E. Burnt/melted live feed wire.
Same problem i had on the XT24, found out that it was the thermostat shorting out the circuit, changed thermostat and worked ok.
Dec 05, 2009 | Heating & Cooling
No power is there a fuse or cut off switch on a Vulcan Quasar Elite G Series HEATER
Not sure wot series mine is, but has 2 thermal, non resetable fuses in it. They are plastic cased (brown) with 2 spade type terminals. You can check them with the power off if you are not confident with the mains.
Make sure it is unplugged. Pull one of the spade clips off the terminal and then check it for continuity.
Jun 06, 2009 | Sunbeam Heating & Cooling
I have a 3 prong wire but dont know how to tell which one goes where
3 prongs, are as follows live wire-- nuetral--- live wire.. the middle terminal is always the nuetral line.. so normal color codes are red(live)-white(nuetral)- black(live), or black(live)--whiite(nuetral)-red(live). so long as you nuetral hooks to center post either live wire can go to either side
Oct 31, 2008 | Dryers
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Hoover UltraCare HC6 150M Front Load Washer Logo
62 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
