The electricity had gone off due to a fault somewhere in the area which switched the tv off (it was on and working fine). the electricity was off 4 about 10mins and then came back on, then went off, then on again, then went off again and finally back on!! once it stayed on we tried to get tv back on but only got a flash of the picture once turned on. the sound was there but no permanent picture- only a black screen. the indicator light is going green but no picture. this was yesterday evening and still no joy from tv. can u help?? have got a 42" philips plasma flat tv.
  • 372 Answers
Hi.
Modern sets dont like power surges which is what happens when supply goes on & off.
I would think that something is damaged it will be expensive to repair.
My advice would be get A shop to check it for you If you can ask them to see if this problem in there opinion is due to power surge.
If you have house hold insurance new for old make A claim.
Hope this helps.
http://dysonmanuals.llc.nu/
Posted on Jun 22, 2008
My BSA A65 engine dies when I turn o0n the headlamp switch. Now the bike won't start and I have no lights working?
Sounds as if you have a short circuit in the headlamp circuit. While this could be anywhere, most likely a pinched wire somewhere you have removed and reinstalled some part. The seat? Replaced headlamp bulb? As to no longer starting, you may have blown a fuse due to the short.
Nov 14, 2014 | General Electric G.E. Arc Fault Breaker
My Humax HDR will not output in widescreen display format! Worked perfectly before!
That is what always happens when something breaks... It would help if you had more info like was there a electrical storm, does everything else work, do the lights light up... I will say this; Most electrical appliance failures are due to no power. As in the switch in the surge protector was turned off when vacuuming the area, etc. So, check all the connections to the wall and then if these are good, by good I mean you replaced them with known working extensions and check the little ground fault button in every outlet too... then get back with more info.
Oct 09, 2014 | Humax Hdr-Fox T2 500Gb Freeview Hd Digital...
Why wont tv turn on today worked fine yesterday? powers up but shuts right back off.
This is a general answer to your question:
Your TV is shutting down because it is consuming too much current from the internal power supply. The power supply has a protection cct
to protect your TV from further damage. If yo have any technical background, then you can follow these simple steps to troubleshoot your TV fault with the aid of a schematic diagram. Let us revise what you need for your job:
1- You need a schematic diagram for your TV model
2- You must be very careful when dealing with powered equippments
3- You need to prepare all the required tools to start your test and repair
4- You must be very confident that you are able to do the job using scientific steps. We all have done many mistakes but at the end we became experts in our fields. Please remember the fault is hidden somewhere and you are going to dig it out.
Let me start now:
-Disconnect any device connected to your TV
-Plug your TV to the Main
-Power on your TV, If the fault is still persisting then check the timer setting of your remote control or take the batteries out. Restart your TV again and if the same problem appear then we need to start our repair now. I personally advice you not to do any think if you don't know what you are doing, but if you want to learn, then do the followings without powering your TV.
- Disconnect your TV cable from the main
- Place and secure your TV on a clean wooden bench.
- Remove the back cover carefully
- look at the boards and identify which is which and compare it with the technical diagram of your TV.
- Identify the power supply section. Remember that 50 % of the TV faults are within the power supply and the rest lies in different area. Furthermore, many faults occurs due to bad soldering, sparks,loose connecters, metallic debris, excessive heat and bad ventilation.
Now if you have identified the power supply board(SMPS) which is very easy to find, disconnect the output jack and test each of the male and female jack pins with the ground. Use an AVO meter (put the selector to ohms) to check for any short cct with the ground. Remembr that there are some pins connect to the ground in both jacks. If you find any thing abnormal then compare your findings with the diagram. Alternatively, you can power your TV and measure the voltages at the output pins of the power supply and compare your readings with the service manual, but please be very careful. Again remember that switch mode power supplies (SMPS)
can work with a range of voltages 90VAC-240VAC, so if you have a step-down transformer from 220VAC to 110VAC, then it would be great and more safe when conducting your tests. In this test we can isolate the fault if it is in the power supply or in a different place. Also remember that your AVO (DC voltage) readings would appear higher than normal because we have isolated the load.
If the power supply was perfect then we are sure now that the problem is somewhere else, but in certain and limited cases some SMPS cannot provide the required power to the load due to internal changes and shifts in the values of the components in the loads and the power supply. In this case you need more experience to identify the source of the problem.
We have now finished from the power supply, however in the old TVs there is another power supply source which is the line transformer. This one is very simple and I am going to discuss that later.
Aug 15, 2014 | Televison & Video
I have an intermittent electrical fault on my 94 dyna wide glide. every so often it just cuts out as if the ignition has been turned off or the kill switch has been pushed. once it stops all the lights,...
"sometimes it starts after jiggleing the wiring loom"
That right there says you have a shorted/broken wire somewhere in the area that you "jiggle", so get an Ohmmeter and start testing in that area.
Mar 30, 2013 | Harley Davidson FXDWG - FXDWGI Dyna Wide...
The tv will not power up, nothing happens when i press the power button
Hello
The power supply section inside your TV is not working. It may be due to a blown fuse, or its inverter secion itself. You have to open your TV to detect and repair the fault. If you are aware in electronics, open it, and check the fuse first. If it is found blown up, replace a new one with same rating. Do not use an other rated fuse, as it may damage more components, if there is a fault inside the circuit section of the power inverter board. If the newly inserted fuse also blow out, as you switch ON the TV, never put any fuse there, and it must be due to some fault to that section, should be checked well. Without any reason, a fuse won't blow up you see. We must find out the reason for that and rectfy it before replacing an other fuse in place. Normally, rectifer diodes, inverter device, a transistor or an STR, whatever may be the case, should check with its schematic diagram, and replace them. Whe power reguator [inverter] side get a fault, it will cause more component in that section to be out of order. So you have to check each component on that section before replacing and switch ON the TV.
If you have a sound knoledge and measuring instruments with you, you can do it by yoursef at home. If not, get it repaired with an experienced service technician. OK.
Apr 15, 2011 | JVC AV-32D305 32" TV
I have samsung(hitron) tv purchased around 4 years before. When the external power supply(switch) to tv is switched on, tv is not receiving any power. i mean tv is not functioning. what would be the...
Give me the model number for more accurate diagnoses....
It seems as though there is a DC problem on the power supply, it could be a simple fuse. Or it could be that a fault on another board is causing the power supply to shut its self down.....The TV is in self protect mode because of a short an open component somewhere. Like I said it could be just a fuse has blown. If the indicator light is on then its probably not a fuse problem, but rather an electrical fault.
http://tvtechwork.webs.com/
Nov 17, 2010 | Samsung Televison & Video
Television won't turn on.
Hello
The same problem i am also facing bin last weak what i will suggest you that neverturn off ur TV by remote switch off directly from the scree from next time it will be helpful for you from next time...
Thanks & Regards
May 24, 2009 | Televison & Video
Dashboard fault
I too have a Peugeot 206 - and has given me nothing but grief - mostly electrical.
The fact you are suddenly losing systems, and draining battery points to a short in the wiring loom - which is a common fault on pugs.
I advise you trace the wire from the rear heater to the fusebox (it's labeled in there). Use a cheap multimeter - pull the fuse out and check the wiring both to the heater (resistance to good earth) and the supply( check for 12V )with the switch on. You may end up undoing the loom cover in the engine bay - but check your feet area first for any damaged wires. Try wiggling the loom with the ignition switch on and in neutral to find the problem. Often just taping it up properly solves it.
Feb 04, 2009 | 1991 Peugeot 405
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
