Question about Sharp R-353 Microwave Oven
No heat what parts had damage if no heat?
  • 375 Answers
It can be both the heat fuse that gone or your pilot light has gone out, check to see if you see a flame while it is functioning, to do this turn on your dryer and watch in the dark so that you can actually see the flame coming on and off or check behind the little door that houses the pilot light to see if you see a flame if no flame relight, this should start your dryer producing heat again
Posted on Jun 22, 2008
Microwave oven makes a lod sound occasionaly, doesnt stop, heating is also normal. I saw some sparks once inside.
The magnetron is partly damaged from sparking that is usually caused when metalic catlery is used even milk parkets with siver lining could damage. In your case the microwave will soon give in and you will have to replace the magnetron.
Aug 03, 2015 | Microwave Ovens
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
My microwave is not heating ... everything is normal.
Ok, the heating device(magnetron) is malfunctioning. it is damaged. this part will cost $133.00 and, you will need to replace this failed component asap if possible.
Jun 16, 2009 | Frigidaire FMV157GM Microwave Oven
Microwave seems to work but does not heat food
OK, you may have a damaged thermostat or, the Magnetron may be damaged as well. you can test each device with a meter(ohm,volt).
replace any parts that dose not register.
Jun 03, 2009 | Panasonic Microwave Ovens
The microwave stopped heating. Everything else is working fine.
Ok, concerning the heating issue. you will need to replace the Magnetron to restore the heating feature in this unit. this device is damaged.
Concerning the motor(circulation). If the motor is not working, this will damaged the Magnetron, due to poor circulation. i recommend replacing the motor asap.
In conclusion, you will need to replace the Magnetron and the circulation motor as well. replacing these two vital devices will fix your issues. the total cost for these parts are estimated at $87.90
Jun 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE IS NOT HEATING
HI, the actual device that produces the heat is damaged or faulty. this device is called the Magnetron. you will need to replace this part in order to restore the heating ability of this microwave oven.
Please rate and have a great day:)
May 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can you microwave an aluminum tray (ex: frozen meal)?
No, this is not recommended. the newer microwave will not flash but, if you put aluminum inside, it will damage the Magnetron. this creates the heat and, if it is damaged, you will lose the heating action in this unit and the Magnetron is not a cheap replacement part.
I do not recommend inserting any aluminum objects at all.
May 27, 2009 | Whirlpool Microwave Ovens
Ge jvm1870 it won't heat anything, all other items work
Ok, if this unit has stopped heating, this will confirm a major fault within the Magnetron. this device is responsible for the heating affect and, you will need to replace this damaged part in order to restore proper heating functions in you microwave oven.
Mar 03, 2009 | GE JVM1870 Microwave Oven
Appears normal
ya this is the same problem i too had...everything will seem to right but the part required for heating might be damaged internally...try changing tat...here i did the same...
Sep 19, 2008 | Frigidaire GLMV168K Microwave Oven
Sharp R-353 Microwave Oven Logo
53 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
