Question about Kenwood Car Audio & Video
Kenwood KDC-W3041 does not save changed settings
  • nick_1551 Jun 22, 2008
    Thanks for you help
It seems as if there's no permanent live to the memory.
If your swap over the black and yellow cables [link black to yellow, and yellow to black], this should solve the problem.
Hope that helps.
Posted on Jun 22, 2008
Kenwood car steroe KDC-108 error 99 code, how to fix?
Try to press the reset button on Kenwood (It returns to factory
settings when the reset button is pressed)
Jan 17, 2015 | Kenwood KDC-108
Hi I have a Kenwood KDC -W3041 car Stereo and when I switch off ignition I loose preset stations any ideas ?? Cheers Lorcan
Yes, there is a wire that is intended to be hooked up to power at all times, and this wire appears to be hooked up to switched power. Look closely at the wiring diagram, in terms of power wires, and find one that is to be switched and one that is to be hot all of the time...
Aug 27, 2011 | Car Audio & Video
KDC-w3041 says PROTECTION when i turn it on
Sometimes if the power is removed it requires a code to be input, to remove the protection, you will have to contact Kenwood, and ask for the code to clear it. This is an anti theft feature. Often the car dealers have these, or try an auto-electrician.. BTW your English is good.
Mar 19, 2010 | Car Audio & Video
Kenwood KDC-W3041 protect
check all the connections between the unit and the speakers check the speakers also and if the problem remains replace the power amp ic.
Mar 09, 2010 | Kenwood Car Audio & Video
When I plug my iPod into my car stereo, it's a Kenwood KDC-W3041, sound only comes out of the speakers in one door, but when I play a CD, sound comes from speakers in both doors. What's wrong?
If your using the aux plug in the front make sure the plug is fully inserted into the ipod and the stereo. then make sure all audio settings are set correctly. If you are using any other type of connection for your ipod ensure the connection is not loose.
Dec 10, 2009 | Car Audio & Video
I need the manual for a Kenwood eXcelon KDC-X993
You can download the original user's manual from Kenwood website. Click on the link below and an online pdf will open in you browser window:
Be sure to have the free adobe pdf installed. You also right-click on the above link and select "save as" to save this online manual for further reading.
To visit Kenwood website for this receiver click here.
Oct 20, 2009 | Kenwood Excelon KDC-X990 CD/MP3/WMA/AAC...
Kenwood kdc-w3041 protect mode
Hello ia737,
The "protect" display is probably being caused by a shorted or grounded (touching vehicle chassis or other ground) speaker wire. Check the speaker wires for bare spots, etc and insulate or replace as necessary.
You do not need to remove the fuses to force a "cold reset" of the W-3041. You can simply press the "reset" button on the front of the unit. It's the little recessed button at the lower left of the volume control. Use the straightened end of a paper clip or ballpoint pen to momentarily hold the button in.
Hope this helps.
Jul 23, 2009 | Kenwood Car Audio & Video
Is remote necessary to reset code on kenwood kdc 319
my CD player is Kenwood KDC-W3041 displayed protect and i can't turn it on. what can i do for that?
Mar 29, 2009 | Kenwood KDC-319 CD Player
Installation in a boat. How to maintain the memory?
A possible method would be to hardwire a rechargeable 12V battery to the yellow wire and ground. The rechargeable does not necessarily have to be high capacity, Actually, a series of 10 AA 1.2volts penlight battery would do the job. Alternately, a small motorcycle battery would probably be better. Wiring wise, pls reference below diagram.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | Kenwood Car Audio & Video
Kdc 5016 time set
Hi go to kenwood site and download the manual for a KDC-516S (it s the same setup as 5016.
or Just press the menu (3 secs) and use the am and fm buttons to nav to the time adjust. then use the arrow keys to change AND SET the correct time.finish by pressing the menu again.
boseman...
Sep 12, 2008 | Kenwood KDC-MP232 CD Player
Car Audio & Video Logo
182 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
