Question about Nokia N72 Cellular Phone
In online mode phone gets hanged
My fone works good in offline mode but when the sim is inside it gets hanged and the battery gets weaken very quickly even i m not using the phone
  • kirandan Aug 29, 2008
    what is lock code
    Problem Solver:
  • 19 Answers
Better u format ur phone . The formatting code is *#7370# . Enter and format May i think the problem will solved
Posted on Aug 23, 2008
How to change a n70 to online mode?
IF YOUR N70 IS SHOWING OFFLINE MODE PROBABLY BECAUSE IT DOES NOT READ YOUR SIM CARD OR YOU SELECT YES AT STARTUP. REMOVE YOUR BATTERY AND BRING OUT THE SIM, REINSERT PROPERLY AND STARTUP YOUR PHONE, THERE SHOULD BE A MESSAGE ON STARTUP " DO YOU WANT TO STARTUP PHONE IN OFFLINE MODE?" PRESS NO, (LEFT UPPER KEY) PHONE SHOULD STARUP ONLINE OTHERWISE YOUR SIM CARD IS NOT BEEN READ.
Nov 13, 2011 | Nokia N70 Cellular Phone
My 6720 nokia phone has gone into offline mode and can not get it back online can you please help as this is a company phone, i have tried taking sim card out, and memory card out, still does not work
This problem occur when the phone gets dropped on a high place, water damage or setting on your mobile is changed.
Please follow this basic solution :
1. with the sim inserted on your phone, go to profile and select GENERAL. might you accidentally set your profile to offline mode.
2. check the simcard socket if its clean or well align,might corrosion is the problem that's why the sim fails to recognized.
3. Also clean the simcard itself using an pencil eraser.
4. align the battery terminal,might the power supply is not sufficient if the ground (middle terminal) doesn't reach the battery interface. as well as clean the battery connector.
If the above method doesn't work,consult a mobile service center for assistance,maybe the sim IC or some components related to insert sim problem maybe damage.
Good luck...
Jun 22, 2011 | Nokia 6720 Classic Cell Phone
Since i switch on my fone is on offline mode
For this issue, you may need to manually search for a network if there's a sim card inside it. Or go to the network options on that phone turn off offline mode. I hope this helps a bit
Mar 09, 2011 | Cell Phones
Sir i hav nokia n70 mobile .i insert the sim in to mobile but phone is everytime offline mode
(1) Pl z go on profile mode and here activate a general profile OK (2) when u open a fone here a msg appear on your fone dat start" fone in offline mode" then u press a NO ok.
Aug 24, 2010 | Nokia N70 Cellular Phone
My nokia 5800 is in offline mode how do i put in online mode with new sim
My Nokia 5800 seems to lost battery charge quickly in 24hrs it's turned it self off because the battery is dead is this usually?
Aug 17, 2010 | Nokia 5800 XpressMusic Smartphone
My NokiaN70 is in the offline mode and I cant get to be in the online mode. On start up it asks continue using the phone in offline mode, when I press the No button it does not respond but continues to...
Offline mode means the sim you have inserted was not detected by your phone.Firstly clean the Sim Card slot(case)and check the connector.If the problem still persist contact nearest mobile repairing center.
Good luck
Visit Again...........Fixya.com
Aug 15, 2010 | Nokia N70 Cellular Phone
Please insert sim
well turn ur fone off and charge it and after some time turn it on and try if does not work install new software on ur fone feel free to ask anything thanx alot.
Jul 28, 2009 | Nokia N72 Cellular Phone
Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Nov 05, 2008 | Nokia e65 Cellular Phone
My Nokia 3250 is in offline mode(Profile) and refuses to change back to a normal mode.
reinsert sim of ur fone and it will ask there continue in offline mode?select NO there and choose another profile....
Oct 09, 2007 | Nokia 3250 Cellular Phone
Nokia N72 Cellular Phone Logo
88 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
