Question about Singer 132QRFB Mechanical Sewing Machine
How to thread & what needles for singer 660 A2 sewing machine
We have just bought a Singer 660 A2 industrial sewing machine which does 'nt have a manual. We would like to know what needle it should use and how to thread the machine. Thank you
  • 139 Answers
You can download a manual here:
Posted on Apr 07, 2010
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
presser feet tutorials,
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 | Sewing Machines
Needle will not pick up bobbin thread
Try installing a brand new needle. Rethread the machine from the very beginning. The machine could be out of time, ie the needle and hook timing do not match.
Nov 18, 2015 | Singer Sewing Machines
How do i fix thread tension on Singer 191D300A industrial sewing machine?
Make sure the bobbin is spinning in the correct direction before you try to sew. Where is the thread collecting? Under the needle plate?
A few other things can be wrong. I will need more information.
San Diego, CA
Embroidery Services
Nov 28, 2014 | Singer Sewing Machines
Threading instructions
There are manuals for several of the submodels of the Singer 81 class here:
Apr 25, 2014 | Singer Sewing Machines
Can you tell me how thick of leather my singer 16 k 33 industrial machine can sew through?
You need to use a leather needle, and thread for leather. Industrial machine require industrial needles.
Apr 10, 2010 | Sewing Machines
Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Dec 29, 2009 | Singer Sewing Machines
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
I am having trouble threading my singer industrial sewing machine I can't remember how
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.Your Industrial machine has a long groove on one side of the needle. This long groove must be on the left side of the needle when it is inserted properly.
Jun 25, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 132QRFB Mechanical Sewing Machine Logo
2,115 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
